Δικαναλος στερεοφωνικος τηλεχειριζομενος ενισχυτης , 2χ120wrms , με audiophile υλικα και ποιοτητα ηχου εξαιρετικη για την κατηγορια τιμης του.
https://www.stereophile.com/content/cambridge-azur-851a-integrated-amplifier
Power output: 120W RMS into 8 Ohms / 200W RMS into 4 Ohms
THD (unweighted): < 0.001% 1 kHz at 80% of rated power
< 0.01% 20 Hz – 20 kHz at 80% of rated power
Audio inputs: 2 sets of balanced XLR, 8 further RCA inputs
Audio outputs: Preamp output, Record output
Frequency response: 10 Hz – 50 kHz +/- 1 dB
S/N ratio (ref 1W/8 Ohm): > 93 dB
Input impedances: Inputs 1 and 2 (balanced): 20 kOhm
Inputs 1-7 unbalanced: 20 kOhm
Rec Input: 20 kOhm
Power Amp damping factor: > 110 at 1 kHz
Max. power consumption: 800W
Minimum power consumption Active (no signal): 70W
Standby power consumption Standby: <0.5W
Bass/treble controls
Shelving type
Max bass boost/cut: +/- 10 dB at 10 Hz
Max treble boost/cut: +/- 7.5 dB at 20 kHz
Dimensions (H x W x D): 115 x 430 x 385mm
Weight: 15.0kg
Αθικτος, Πλήρης συσκευασία, 1050 Ευρώ.
6342980705 Σπύρος
Rec Input: 20 kOhm
Shelving type
Weight: 15.0kg
6342980705 Σπύρος
