Camera Sony DCR-IP1E
Technical specifications DCR-IP1E
Please be aware that the features/specifications can differ from country to country.
Collapse all
Audio
Audio System
MPEG1 Audio Layer2
Audio Dubbing 12bit
ΝO
Built in Microphone
Stereo
Built in Speaker
YES
Bluetooth
Basic Imaging Profile
NO
Dial-up Network Profile
NO
Gereric Access Profile
NO
Max. Baud Rate (kbps)
0.0
Operating Frequency Band (GHz Band)
0.0
System Version
N/A
Camera
Image Device: Size
1 / 5.0
Image Device: System
Interlace
14bit DXP
YES
Advanced HAD technology
YES
Number of Pixels Gross (K)
1070
Number of Pixels Act Camera mode (K)
690
Number of Pixels Act Memory mode (K)
1000
Focus: Full Range Auto
YES
Focus: Manual
YES
Manual Focus Key
Panel
Spot Focus (Touch Panel)
YES
Spot Meter
YES
Minimum Illumination (lux)
7.0
SteadyShot (Image Stabilisation)
Super (Electronic)
Camera Noise Reduction
YES
Shutter Speed
1/2-1/4000
White Balance
Auto/Outdoor/Indoor/Hold
Program AE
Portrait/Beach & Ski/Sports Lesson/Landscape/Spotlight/Sunset & Moon
Backlight Compensation
YES
Interval Rec.
NO
Fader
Black, Mosaic, Monotone
Dimensions
Depth (mm)
69.0
Height (mm)
91.0
Width (mm)
39.0
Jacks
Audio Input
YES
Audio Output
ΥES
Video Input
YES
Video Output
YES
S-Video Input
YES
S-Video Output
YES
i.LINK (DV) Input
NO
i.LINK (DV) Output
NO
i.LINK (MICROMV) Input
YES
i.LINK (MICROMV) Output
YES
USB Terminal
YES
Lens / Zoom
Lens
Carl Zeiss Vario-Sonnar
F1.8-2.3
f (Focal Distance) (mm)
3.2-32
f (35mm conversion): Camera mode (mm)
46-460
f (35mm conversion): Memory mode (mm)
38-380
Zoom Ratio (Optical)
10.0
Zoom Ratio (Digital)
120.0
Precision Digital Zoom
YES
Zoom Key
Lever
Still Image Recording
Compression of still image
JPEG
Recording Media
Memory Stick DUO (Serial only)
Memory Stick PRO Compatibility
YES
Progressive Scan
NO
Progressive Shutter System
YES
Image Size: Max
1152 x 864
Image Size: VGA
640 x 480
Max. Number of Recording Pictures (Supplied Memory Stick)
120.0
Still Image Recording Mode Fine
1 / 4
Still Image Recording Mode Standard
1 / 10
MPEG Movie
AX
Burst Record
No
Burst Record Auto Exposure Bracketing
YES
Burst Record Multi 9 Pictures
NO
Number of Recording Pictures in Best Mode (Supplied Memory Stick)
15.0
Format
MPEG1
Index Playback
YES
Memory Mix
YES
Recording Mode
Light(160x128, 10fps)/Standard(160x128, 10fps)/Fine(352x288, 25fps)/Superfine(352x288, 25fps)
Others
16:9 Wide (Full) Recording
YES
Accessory Shoe
NO
Battery Info
YES
Built in Light
NO
Demonstration Mode
YES
InfoLITHUM System
YES
Max. Continuous Recording Time with Optional Battery and Viewfinder (min)
175.0
Picture Effects
Mosaic,Solarization,Monotone,Sepia,Negative Art,Pastel
Digital Picture Effects
Still,Flash Motion,Luminance Key,Slow Shutter,Trail, Old movie
Power Consumption : LCD (W)
3.7
Continuous Recording Time with Supplied Battery and Viewfinder (min)
85.0
Progressive Recording Mode
NO
USB Streaming
YES
Weight without Tape/Battery (g)
230.0
Supplied Accessories
AC Adaptor
AC-L25
AV Cable
Stereo AV
Lens Cap
NO
Memory Stick (MB)
8.0
Rechargeable Battery Pack
NP-FF51
USB Cable
YES
USB Driver
YES
Editing Software
PIXELA ImageMixer ver1.5 / MovieShaker ver3.1
Stylus Pen
NO
Shoulder Strap
NO
Wrist Strap
NO
Tape / Cleaning Tape
NO
Wireless Remote Commander
RMT-832
21 Pin Adaptor
YES
View Finder / LCD Monitor
Hybrid LCD Screen
YES
LCD: Size (inch)
2.0
LCD: Pixels (dots)
211200.0
Touch Panel
YES
Viewfinder
Recorder/ Player
Format
ΜICROMV
Dubbing and Editing
No
Hi8/Video8 Playback
NO
LP Recording
NO
Cassette Memory
YES
NTSC Playback on PAL TV
YES
Playback Zoom
YES
Signal Convert Function
NO
Τιμη 250 ευρω
Τηλεφωνο επικοινωνιας 6932201836
xkaragi
