Cardas Audio - Golden Reference
Κώστας Φ.
Golden Reference speaker is the latest evolutionary speaker cable design by George Cardas. It features Cardas patented "Golden Section", multi-gauge stranding in a symmetrical, 12 conductor, helical triad of quad-axial planetary arrays of golden ratio, constant Q conductors.
Cardas patented, "Constant-Q" construction places the smallest of the Golden Ratio strands at the center of the conductor to reduce stored energy and conductor resonance. Cable resonance is further reduced with controlled propagation, Crossfield construction, matching conductor and cable loop characteristics with carefully computed strand layering. Cross layered conductors reduce EMI and RFI to a new low. All conductors are individually coated to insulate and prevent oxidation.
Golden Reference is a perfectly neutral reference cable with unmatched transient purity. Golden Reference is perfectly symmetrical and non directional. Like all Cardas cable, Golden Reference is individually inspected, and hand terminated using Rhodium plated connectors and Cardas formulated Quad Eutectic solder, for a lifetime of listening pleasure.
  • Outside Diameter: .702
  • Dielectric Type: Teflon®, Air
  • Inductance: .031 uh/ft/loop
  • Capacitance: 216 pf/ft
  • Bi Wire Option: Yes
  • Tri Wire Option: Yes
  • Discrete Conductors: 816
  • Cable AWG: 5
  • Conductor Type: Matched Propagation, Golden Ratio, Constant Q, Crossfield, Pure Copper Litz
Golden Reference Termination Costs: No extra charge for any Spade, except 9 mm. No extra charge for Economy Banana Plugs and Maggy Pins. Check with your Dealer for pricing on Cardas/Colver Bananas or other connectors from Cardas, Spekon, Fisher, etc.
Golden Reference is the latest evolutionary interconnect design by George Cardas. It features Cardas patented “Golden Section”, multi-gauge stranding in a symmetrical, helical tri-axial design. Thin wall, Teflon® air tubes are used as dielectric and provide air suspension for the conductors. Cardas patented, “Constant-Q” construction places the smallest of the Golden Ratio strands at the center of the conductor to reduce stored energy and conductor resonance. Cable resonance is further reduced with controlled propagation, Crossfield construction, matching conductor to dielectric characteristics with carefully computed strand layering. Multi-layer shielding and cross layered conductors reduce EMI and RFI to a new low. All conductors are individually coated to insulate and prevent oxidation. Golden Reference is a perfectly neutral reference cable. It sounds the same at any length, between any component, at any originating or terminating impedance. Golden Reference is perfectly symmetrical and non-directional. Like all Cardas cables, Golden Reference is individually inspected, and hand terminated using Rhodium plated connectors and Cardas formulated Quad Eutectic solder, for a lifetime of listening pleasure.
  • Outside Diameter: .415
  • RCA Capacitance: 12 pf/ft
  • XLR Capacitance: 7 pf/ft
  • Cable AWG: 26 x 3
  • Shield Type: 100% spiral x 2 and Teflon graphite composite
  • Conductor Type: Matched Propagation, Golden Ratio, Constant Q, Crossfield, Pure Copper, Litz
Golden Reference Termination Costs: No extra charge for any RCA or XLR. Check with your Dealer for pricing on other connectors.
The Golden Reference power cord provides the ultimate current flow, excellent isolation between components and broad band power line filtration. It is shielded and relatively flexible for its size.
Reviews:
:cool_1: :cool_1: :cool_1: :cool_1:
Ec_K
