Carver Digital Introducing 5.1 Home Theater Amplifier
Σπύρος Μπλάτσιος
Διακεκριμένο μέλος
Carver Digital will be introducing the new multi-channel HTA 5.1 Home Theater Amplifier that features 200 watts per channel for five or seven channels of surround sound. The HTA 5.1 Amp will debut at the Consumer Electronics Show (CES), which begins January 6th in Las Vegas.
The HTA 5.1 is ideal for use in audio and Home Theater systems, as it features an efficient Class H power design and a high-current, modular configuration that minimizes power loss and allows cool operation.
The amplifier can be configured for five channels and expanded to seven. In five-channel mode, it delivers 200 watts per channel into 8 ohms, 300 watts into 4 ohms, and 400 watts into 2 ohms, each with less than 0.15 percent THD. Power handling at the 2-ohm level is completely stable. At seven channels, the HTA 5.1 can deliver 200 watts per channel into 8 ohms. Frequency response for the amplifier is 20 Hz-20 kHz +/- 0.1 dB, or 10 Hz-100 KHz +/- 3dB. The signal-to-noise ratio is - 100dB, unweighted.
The amplifier’s True Card cage design accommodates up to seven mono block power modules that are on nylon rails, and feature low-noise toroid power transformers with high-speed rectifiers. Additional features include, transparent soft clip circuitry, soft start circuitry, a soft touch power switch for silent turn on/turn off, signal- and remote-sensing automatic turn-on. Aluminum capacitors provide reliability, and a quiet fan assures cool operation.
The amplifier’s LED displays include channel status indicators for Standby, Operate and Fault. Connections include both balanced XLR and unbalanced RCA inputs. The HTA 5.1’s chassis occupies five rack units and features a milled aluminum faceplate.
Carver Digital’s HTA 5.1 Home Theater Amplifier will be available in spring of 2005 at a suggested price of $2,995.
από το audio video revolution http://www.avrev.com/
Gianni Tab
