Cas Interface 3 Programer
Sas Parakalo.. Xeri Kanis Giati Den Mporo Na Programatiso Tin Dragon Card I To Dragon Cam ?.. Kano Olla Osa Grafi To Manuall, Arxizi O Programatismos ,ke Meta Apo Ligo Mou Grafi Provlima Epikinoniako [comunication Eror] ....efxaristo Prokatavolika Spiros Spinoulas. Ysterografo..giasas Ellines Apo Ola Ta Miki Ke Plati...
Έχεις Cas3+ με Usb σύνδεση?
Έχεις φορτώσει τους οδηγούς όπως ακριβώς λένε οι οδηγίες.
Χρειαζόμαστε περισσότερες πληροφορίες.....
ANDREA .EFXARISTO POLI GIA TIN AMESI ANTAPOKRISI...OK SINDESI[ USB ].ALLA AS TA PAROUME APO TIN ARXI . KATEVAZO TO PROGRAMA STUDIO CIS 79c TIS DUOLABS ,META TO TOPOTHETO -RUN AND INTALATION-META TI DIADIKASIA AFTI DIPLO CLIC STIN IKONA KE VGAZI TIS GLOSES OPOU DIALEGO MIA META ME ROTAI AN THELO NA MOU TOPOTHETISI TOUS ODIGOUS CLIC NE ,META TOPOTHETO TON PROGRAMATISTI TIN TREX KE ARXIZI TO GRAPSIMO ,POU SIMFONA ME TO MANUAL PERNI MONO 20-25 LEPTA ,AFTO OMOS KANI PANO APO 90 LEPTA ,KE PRIN TELIOSI MOU GRAFI COMUNICATIOS EROR 200000015 .Y.G TIN CARTA TIN EPIDIORTHONO KAI -ERASE- PROTOU ARXISO NA GRAFO -.. YPOXREOMENOS SPIROS -APO LONDINO .XERETISMOUS STIN AGAPIMENIMOU PATRIDA..
den ine [t.rex cam] ine[ t.rex card] tin de dummy card tin vazo monon sto [dragon cam]ston opio otan arxiso tin engafi tis dragon cam, den ginete tipota. mipos ta programata tou studio 7.9 tha prepi na ta anixo me [winzip?]giati dokimasa ke den mporesa. mipos i duolabs mas koroidevi?me alla logia den iparxoun arketes plirofories sto- manuall- . an omos esy xeris ,stilemou analitika tis odigies se parakalo ke tha sto xrostao.......giati pedevome polous mines ,mexri pou ithela na agoraso kenourio compiouter giati nomiza oti ftei afto.xeretismous apo londino ne liakada..
Από το forum της Duolabs
Hi
How to program dragon cam.
Start cas 7.5.
select cam module logo.
select other cams.
select dragon cam logo.
connect dummy card to cas3.
gently insert dragon cam.
Then insert dummy card contacts upwards into cam.
Then load file to be loaded Ie DRA FORMAT FILE IE PREDATER.
Then you will see prepairing to load in host pmcia diolog box.
Then you will see dragon load.
Then you double click the word dragon load.
then you see.
YES LOAD
DO NOTHING.
SELECT LOAD
Then click enter selected button.
Then cam will load takes about 12 to 15 mins.
When you get success message.
close cas software.
Insert cam in to receiver.
Then reset receiver and predater should show up in ci menu of receiver.
If you see dragon load reset receiver again.
HOPE YOU FIND THIS USELFULL
BEST REGARDS(GEDTHETED)
PROTA apo olla thanksyou gia to [duolabs forum instraction page] to opion toxo kani print,me odigies apotous [obi wam,+ gedthered administrators of duolabs forum]..to provlima ine pou tha vro to katalilo program gia to kathe ti?ke pos? -p.x.Ie DRA FORMAT FILE IE PREDATER- THANK YOU SPIROS POLY XIONI SIMERA EDO STO LONDINO...
l.koustimpis@visualacoust
