CD player από το διάστημα...
Μόλις προσγειώθηκε...
ΚΙΝΕΖΟΑΓΓΛΙΚΑ ή CHINESLISH !
Outstanding features of Shanling CD-T300 tube CD player
with full balanced output and rocker transport
日本NPC精密电路公司的SM5847超采样滤波芯片
Japanese NPC SM5847 over-sampling and filter chip.
BB公司8片PCM1704K作数字/模拟转换,每声道采用4只并联输出(平衡输出时每臂2只并联使用)
Eight Burr-Brown PCM1704K D/A converter chips, four per channel in parallel for single-ended output, two per channel in parallel for balanced configuration.
BB公司12片OPA627作I/V转换及低通滤波
Twelve Burr-Brown OPA627 chips for I/V conversion and low pass filtering.
四只俄罗斯EH6922镀金脚电子管作输出放大
Four Russian EH6922 vacuum tubes with gold plated pins for output amplification.
纯净电源分体式设计
Clean electric power from a separate power supply.
飞利浦著名"摇臂王盘"CDM-4
Famous Philips "King of the rockers" CDM-4 transport.
LED 5 X 7智能点阵显示屏
5×7 lattice LED display screen with INTELLIGENT DISPLAYS technology.
采用最稳定的三点式支承系统
Three point support of the best kind.
机芯多重防谐振结构
Multiple anti-vibration construction to isolate the transport mechanism.
精细打造全铝合金机身结构
Custom-made aluminum alloy chassis, built with meticulous craftsmanship
Ο ΔΙΑΣΤΗΜΙΚΟΣ ΚΙΝΕΖΟΣ ΘΑ ΦΟΡΕΘΕΙ ΠΟΛΥ ΦΕΤΟΣ! :shock: :shock: :shock:
roberto_portale
