Certus makes turntables luxuriously hip again
Απάντηση: Certus makes turntables luxuriously hip again
Now that we live in the iPod era, people get nostalgic about the way things used to be while at the same time voting with their dollars and buying still more, modern plastic and lifeless products that are void of any real personality and charm. Few things however can match a beautiful old turntable.
It has substance and style. You can smell the wood and it has a an actual beautiful personality and presence while sitting sitting there. Certus Turntables aim to bring back the style and elegance of a time not very long ago. The only difference is that they come with the latest technology packed inside. The Certus motor for instance uses revolutionary applications of materials, which result in a richer music experience.
The Certus Turntable by Teres Audio comes in two flavors, the 460 and the 450. The 460 model has two armboards with the Gibraltar isolation stand and the 450 comes with everything available on 460 but the additional brass and hardwood base and the dual armboards. Pricing starts at $13,900. A top of the line model will cost $25,500. When is the last time you saw an iPod or Cd player look like this?
Gebreselassie
Μαύρος!
Re: Απάντηση: Certus makes turntables luxuriously hip again
Ας απομονώσω μερικές λέξεις/φράσεις: :126:
luxuriously hip
nostalgic
lifeless products
real personality
charm
substance and style
smell the wood
elegance
flavors
Τι ωραία που θα ήταν αν μιλούσε κάποιος και για high fidelity, εκτός από τα φρου φρου και το marketing. Μα είναι δυνατόν να απευθύνονται μόνον στην... τρίτη ηλικία, που πέφτει με αυτές τις μπούρδες; :137:
αμ αυτοι εχουν τα λεφτα να το αγορασουν Νικο, ποιοι ταχουν οι ατσιγαροι πιτσιρικαδες;
Γράψε τις λέξεις αυτές σε ένα χαρτάκι και έχε το μαζί σου στις παρουσιάσεις (αυτές τις βαρετές που κάποιος μιλάει κάνα μισάωρο χωρίς να ακούς το μηχανάκι).
Συγκεκριμένα κάνε τες ένα πίνακα 3χ3 (έχεις αρκετά) 4χ4 (θες περισσότερες λέξεις) κ.τ.λ.
Υπομονετικά όσο μιλάει ο παρουσιαστής κοίταζε το χαρτάκι.
Σημείωνε κάθε μια λέξη που είπε ο παρουσιαστής
Όταν κάνεις τριάδα αλλά τρίλιζα (XXX)
Σήκω πάνω και φώναξε BULLSHIT
Έτσι κανείς δε θα καταλάβει ότι τόση ώρα βαριόσουν την παρουσίαση, και θα είναι σίγουροι ότι έχεις σημειώσει τα πάντα… Άσε που θα τους πιάσει και κρύος ιδρώτας… Θα σου πουν κάτι ξέρει αυτός…
Gebreselassie
Μαύρος!
Σωστά. Βασικά το πρόβλημά τους είναι ότι όλοι οι λεφτάδες δεν είναι ηλίθιοι. :137:
bmavroeidis
