Christie LWU420 WUXGA Projector Review
[imgl]http://www.projectorcentral.com/img.cfm?pid=5769[/imgl]Combine the best features of large-venue and portable projectors and you get the Christie LWU420, a WUXGA powerhouse with flexible lensing, a bright high-resolution picture, good contrast and color, and the ability to take it all on the road. Lumen output is not quite as high as expected, with a 23% shortfall from specifications, and the usefulness of the lens shift function could be improved significantly with a slight range expansion. But as a hybrid product, the LWU420 shines. If you need the ability to display highly complex material at full resolution outside of a dedicated viewing environment, the LWU420 is the way to go.
Source: projectorcentral.com
simplygades
