Classe Delta CP 500 & CA 2200
sps
CP-500 PREAMPLIFER
model CP-500
frequency response 20Hz - 20kHz ± 0.1dB
distortion (THD + noise) 0.003%
analog section
single-ended input (max level) 5Vrms
single-ended output (max level) 10Vrms
balanced input (max level) 10Vrms
balanced output (max level) 20Vrms
Signal to noise ratio (unweighted) 20Hz to 500kHz 100dB
channel separation >110dB
inputs
single-ended inputs 3pr RCA / 100kΩ
(no./impedance)
single-ended tape inputs 1pr RCA / 100kΩ(no./impedance)
balanced inputs 2pr XLR / 200kΩ
(no./impedance)
outputs
single-ended 1pr RCA
balanced 1pr XLR
tape out 1pr RCA
weights & measurements
width 445 mm
depth 419 mm
height 121 mm
net weight 12 kg
CA-2200 POWER AMPLIFIER
model CA-2200
(balanced inputs)
voltage gain 29.1dB
bandwidth 155kHz (-3dB)
bandwidth 22kHz (-0.1dB)
phase < -10° (22kHz)
sensitivity 1.4Vrms
power/channel (continuous)
(230VAC line, 1kHz signal regulated to 1% THD + noise into resistive load, all channels driven)
load (resistive)
200W
400W
THD + noise (unweighted, 10Hz - 500kHz bandwidth, 1Vrms/1kHz input)
load (resistive)
none 0.002%
8Ω 0.003%
4Ω 0.005%
noise FFT noise floor peaks all below –95dBV
(with terminated inputs)
S/N ratio (relative to 1kHz sine wave full level output into 8Ω) 108dB
height 222mm
depth (excluding connectors) 470mm
width 445mm
net weight 42kg
idle power consumption 166W
rated power consumption 480W
ΤΕΛΕΙΑ ΚΑΤΑΣΤΑΣΗ !!!
Πρώτο Χέρι, Πλήρης Συσκευασία,
Ο Classe Διαθέτει Ρολοϊ που Φαινονται οι Ωρες που έχει Λειτουργήσει !
Τιμή 4.400 Ευρώ 6942980705 Σπύρος
sps
sps
Τιμή 4.000 Ευρώ 6942980705 Σπύρος
sps
sps
sps
Τιμή 4.000 Ευρώ
sps
Τιμή 4.000 Ευρώ
sps
Ευχαριστώ το φόρουμ για την φιλοξενία, ο Ενισχυτής έφυγε. Παρακαλώ να κλείσει.
Παναγιώτης2009_
