Coltrane Supreme with diamond midrange
gkontoletas
trouble in my brain
Frequency range: 90-100 000 Hz ±1.5 dB
Power rating: 300 W continuous, 1500 W peak
Sensitivity: 93 dB/W/m
Impendance: 4 Ohm (minimum 3.6 Ohm)
Type: Sealed box system
Drive units: Four 7�ceramic-woofers, one 7�lower ceramic-mid, 2�diamond-mid, 3/4�diamond tweeter
Crossover network: Second and first order: 330, 1200 and 8000 Hz
Terminals: Custom made, biwiring
Cabinet: 25 mm:s carbon fibre laminate sides, 60 mm wood front, back, top and bottom,
Stands: Polished steel with Black Diamond Racing cones and pucks
Finishes: High-gloss carbon fibre sides with Oak, Maple, Cherry or Walnut.
Dimensions: W x H x D 26.0 x 137.0 x 40.0 cm
Net weight: 70 kilos
Subwoofers
Frequency range: 15-100 Hz -3 dB
Power rating: 800 W continuous, 4 000W peak
Impendance: 4 Ohm (minimum 4.0 Ohm)
Drive units: Six 9�ceramic woofers
Crossover network: Fourth order fully balanced active crossover 110 Hz with digital active room correction possibilities
Dimensions: WxHxD 36.0 x 176.0 x 50.0 cm
Net weight: 90 kilos
http://www.martendesign.com/base.html
http://www.swedishstatement.com/2_setup.htm
DimAster
