Copland Cda 823
CDA 823 High Resolution CD player, 24-bit Dual differential D/A converter, 192 kHz oversampling,
Frequency response 20 Hz 20 kHz +/- 0.1 dB
S/N ratio (IHF-A curve) Better than 100 dB
Phase linearity Less than 0.2” (20 Hz 20 kHz)
Dynamic range Better than 100 dB
T.H.D. Less than 0.01 %
Output Analog Balanced and single ended: 2.0 V rms.
Output digital S/PDIF. 0.5 V p-p/75 ohms
Power consumption 40 W
Normal mains voltage 115 V or 230 V factory set for destination country only
Mains voltage range +/- 12%
Dimensions 430 (W) 110 (H) 390 (D) mm
Weight 9 kg
kriono
