CoreAVC v.2
gkontoletas
trouble in my brain
Η CoreCodec είναι σχεδόν έτοιμη για την παρουσίαση του νέου CoreAVC v.2.0.0, αυτή τη στιγμή κάνει τις τελευταίες δοκιμές.
Το παρακάτω video παρουσιάζει μερικές από τις δυνατότητες του νέου CoreAVC v.2.0.0.
http://www.youtube.com/watch?v=uQqmBXvIInA
gkontoletas
trouble in my brain
Απάντηση: CoreAVC v.2
Παρουσιάστηκε επίσημα από την CoreCodec ο νέος CoreAVC 2.0.0.
CoreAVC v2.0: What's new in this release
CoreAVC H.264 Video Codec - Version 2.0.0.0 (20091218)
- ADD: Initial support for Windows 7
- ADD: Support for Windows Media Center (in .MKV)
- ADD: Custom fourcc to match the Haali splitter
- ADD: Support for Non-Compliant Motion Vectors (MV)
- ADD: mmx optimizations
- ADD: mmx2 optimizations
- ADD: sse optimizations
- ADD: sse2 optimizations
- ADD: sse3 optimizations
- ADD: ssse3 optimizations (almost 70)
- ADD: sse4 optimizations
- ADD: faster handling of pure-DC chroma blocks
- ADD: new x86 cpu caps
- ADD: Multi-dupe weightp (+Future x264 changes)
- ADD: 64bit support
- FIX: Fix potential failure in CABAC MVD decoding.
- FIX: Proper alignment intrinsics for MSVC and GCC.
- FIX: AVC SEI+userdata fix
- FIX: Focus bug in Windows Media Center that disabled CUDA
- FIX: Better frame re-ordering on difficult streams
- CHG: Supports 16 CPU Cores (was 4 cores max)
- CHG: Support for QuadHD resolutions(4096×4096)
- CHG: New dc_add
- CHG: Faster CAVLC
- CHG: Faster CABAC
- CHG: Faster Deblocking (Massive deblocking overhaul)
- CHG: SSSE3: Faster Motion Compensation (20% faster on Core 2 Conroe and more for Penryn)
- CHG: New CoreNumber for 2.0
- CHG: Initial support for CoreAccount. Linking purchase+account
- CHG: Integrated the Haali splitter into the installer
- CHG: New installer supports both 32/64 bit Operating Systems
- CHG: Filter compiled against ICC (2% speed increase for modern Intel Processors)
- CHG: Updated IDCT to support ARM NEON Cortex A8 Support
- CHG: Updated Blitter YUV/RGB for ARM NEON Cortex A8 Support
- OEM: Initial ARM NEON Cortex A8 Support (iPhone, Touch, Linux, Windows Mobile)
- OEM: SDK NVIDIA CUDA 2.3 support
- OEM: Removed the windows direct3d requirement for CUDA (it can now be native)
- OEM: Updated GStreamer plug-in
Haali Media Splitter (20091112)
- ADD: Official 64bit support
- ADD: Official support for Windows 7
- ADD: Custom fourcc option for windows 7
- ADD: Silent install flags for each install option
- CHG: Disabled explorer thumbnail support (off by default)
Haali Media Splitter supports the following command line options:
/S - silent install without any UI
/MKVONLY - register only Matroska components
/AVI=[yes|no] - register AVI support
/MP4=[yes|no] - register MP4 support
/OGG=[yes|no] - register OGG/OGM support
/TS=[yes|no] - register MPEG TS support
/PS=[yes|no] - register MPEG PS support
/WMP=[yes|no] - register WMP to play in Windows 7
http://corecodec.com/products/coreavc
Nickk
