gkontoletas
trouble in my brain
Η νέα έκδοση του CoreAVC είναι γεγονός, η μεγάλη αλλαγή σε σχέση με τις προηγούμενες εκδόσεις είναι η υποστήριξη των καρτών της Intel.
Οι νέες δυνατότητες και οι βελτιώσεις:
- ADD: 9 bit support
- ADD: 10 bit support
- ADD: DXVA fallback to software
- ADD: Intel Media SDK Support (DXVA2)
- ADD: Intel GMA Support (DXVA2)
- ADD: 10 bit output format (P010)
- ADD: 16 bit output format (P016)
- ADD: Directshow dithering when filter output is downsampled
- ADD: Improved DXVA handling for interlaced streams
- ADD: Colorspace conversion from 10 bit formats to 8 bit formats
- ADD: DXVA 2 Long slice support
- ADD: Initial 4:4:4 integration (No decode support yet)
- ADD: New assembly engine
- ADD: New assembly IDCT
- ADD: New assembly motion compensation
- ADD: New assembly inter-prediction
- ADD: New assembly weighted prediction
- ADD: New assembly 9-bit
- ADD: New assembly 10-bit
- ADD: Improved assembly 8 bit performance
- CHG: Use container AR when there is no stream AR
- FIX: Improved Frame order handling
- FIX: Hardware deinterlacing field order
- CHG: DXVA increase max buffers
- CHG: Sanitize sample stop times for buggy splitters, for hardware deinterlacing compatibility
- FIX: Better recovery point handling, reduces artifacts for poorly cut streams
- SDK: Updated xcode support for iOS and OS X
- SDK: Improved APIs
- SDK: Fix: Missing APIs
- SDK: Initial support for MVC (CoreMVC) integration
Haali Media Splitter - Version 1.11.233.7 (20110830)
- FIX: Various DTS Audio bugs
- ADD: Improved DTS support
- ADD: Support for MVC 3D videos
http://corecodec.com/products/coreavc
- Supports Windows 7
- 32/64 bit Support
- 8/9/10-Bit Hi10/Hi10P Support
- DXVA 1/2 Compatible
- NVIDIA CUDA GPU Support
- ATI GPU Support (DXVA)
- Intel Media SDK Support (DXVA)
- Multicore ready (Unlimited CPU Cores)
- 8100x8100 Resolution Support
- Full Interlaced support
- Uses Directshow for MKV
- Haali Media Splitter Included
