σαν καινουριο.συναλλαγες μονο θεσσαλονικη λογο ογκου.
FIT MASSAGE / CRAZY FITNESS
Ten minutes daily in the platform of oschllations - vibration FIT MASSAGE / CRAZY FITNESS will help you turn away the unnecessary grease from the middle, the abdomen and legs.
It allocates screen in order to measure the time you are exercising, the speed but also the combustion of grease.
The exercise with FIT MASSAGE / CRAZY FITNESS helps in the circulation of blood, it eliminates the pain, it increases the elasticity of skin.
The modern method in the slimming !
Biggest weight of user : 120kg
τιμη 100 ευρο
http://image.made-in-china.com/2f0j00AZwQKOPJiTkS/Crazy-Fit-Massager-FM-05B-.jpg
τιμη 100 ευρο
