Cross-Upmixing (Dolby, DTS, Auro-3D)
But it is not as simple as it is in our introduction, because currently this very profitable
A special feature of the aforementioned D & M models is now the "Cross-Upmixing". In a nutshell, this means that, for example, DTS-encoded material can not only be "mixed up" using DTS Neural: X, but optionally also with Auro-Matic or Dolby Surround. The user therefore has the free choice of which of the three Upmixer you want to use each.
function has already been put off the hook. New models (AV receivers, AV amplifiers or AV preamplifiers) released after January 1, 2019 need to be certified to the new Dolby specification, which prohibits the use of third-party upmixers on Dolby material. Devices that were brought before the market may be produced without recertification until the end of 2020. That means: If you want to have an AV receiver with full cross upmixing functionality, you should now plan the new purchase.
https://translate.google.gr/transla...on-und-marantz-avr-avv-av-vorstufen-modellen/
για τους μη πιστοποιημενους η λυση upmix ειναι απο το player μετα το τελος του 20 ;)
Diylover
Φτιάχτε ενεργά!!!
Ναι, έχουμε καταντήσει κάθε χρόνο να θελουμε άλλο pro..
ΧΡΗΣΤΟΣ ΔΟΞΑΣ
