Crystalio II
gkontoletas
trouble in my brain
http://www.pluggedin.tv/item--Cryst...ion-Video-Processor-Media-Player--CrystalioII
VPS3300 VPS3800 (’Pro’)
FEATURES
Rich inputs/outputs Extremely flexible and high quality inputs/outputs.
High quality BNC connectors are used for all analog/SDI video I/O.
VXP™ by Gennum Uncompromised HD motion adaptive de-interlacing with 3:2 and 2:2 inverse telecine, bad edit correction and advanced dynamic directional interpolation for eliminating jaggy artifacts; image enhancements for improving details and true 10-bit broadcast-grade processing to deliver the world’s most advanced and flexible image processor.
2:2 and 3:3 processing Cadence lock to 48Hz and 72Hz for film source to provide ultra-smooth playback.
Adaptive 3D noise reduction Reduce unwanted video noise and produce more enjoyable motion pictures.
Ultra-Fine Audio Delay™ Audio can be delayed to match the onscreen actions perfectly.
Precise picture control Besides the conventional brightness, contrast, hue, saturation & picture controls, Crystalio II offers advanced controls such as sub-pixel Y/C delay calibration, user-customizable gamma curve through the user-friendly graphical interface and more.
Friendly user interface Crystalio II is designed as a user-friendly plug-and-play appliance. Alpha-blended OSD (on screen display) offers an intuitive graphical user interface. 10 user-customizable independent picture control profiles for each input. Input and Output configuration profiles. Access to 24 user-customizable macros from the backlight remote for quick access to the most frequently used features.
DynamicVP™ When enabled, the image processing settings and output format/timing/configuration will change dynamically depending on the input formats. This is an extremely flexible feature for advanced users to apply various image processing options to a single video source with different formats, and CRT users to exploit the sweetspots of their display dynamically.
UltraAR™ Crystalio II supports virtually any video image aspect ratio and display devices aspect ratio including, but not limited to; video images ranging from 4:3, 16:9, 4:3 letterbox, 16:9 letterbox, to 2.35:1 anamorphic; and display device aspect ratio from 4:3, 16:10, 16:9, to 2.35:1. Non-linear stretching to display 4:3 image on 16:9 displays is also supported.
Pixel Magic System™ Pixel Magic System™ is a set of tools including internal test pattern generator for the user to configure the video output of Crystalio II, ensuring that it is mapped in Pixel Perfect mode to your digital display.
Chroma filter Chroma filter to mask the chroma bug of MPEG decoders.
3D/2D 5-line comb filter 3D/2D 5-line (5H) adaptive comb and chroma trap filter for both PAL and NTSC signals delivers excellent analog to digital video conversion, especially valuable for the VCR/LD users.
LCD display and push buttons on front panel Real-time status information display on LCD panel including source, video format, output resolution, deinterlacing, aspect ratio, overscan and more. Push buttons/LCD display for system configuration and control is available in the situations where the user cannot view the display devices directly.
Dual deinterlacer architecture Dual deinterlacer architecture for SDTV material allows choice of VXP by Gennum and DCDi by Faroudja.
HD-SDI The 2 SDI inputs are HD capable. HD-SDI is the most mature and highest quality technology for HD transport.
Precision clock Video circuits and audio delay circuits are clocked by 1ppm high precision low jitter TCXOs (temperature compensated crystal oscillators) and produce the highest quality standard of video and audio output.
Media player included MPEG1/2/4 decoding capability to provide high quality media playback. External USB disks and/or the included 200GB internal hard disk can be used to store various video clips including the MPEG2 TS video taken by the new HDV cameras.
INPUTS
SDI (support SDTV only) x 2
HD-SDI (support SDTV/EDTV/HDTV) x 2
HDMI with HDCP and embedded digital audio x 4, support SDTV/EDTV/HDTV and PC resolutions
SDTV YPbPr component video inputs x 2, each can be configured as RGBS or 2 composite + 1 S-video
SD/ED/HDTV YPbPr component video inputs x 2, one of them can also be configured as RGBHV or RGBS
Analog stereo audio inputs x 3
Digital audio inputs x 4, 1 optical + 3 electrical
Firewire IEEE1394 inputs (reserved for future use) x 2
OUTPUTS
HDMI with HDCP and embedded digital audio x 2
BNC x 5, configured as RGBHV/RGBS or YPbPr
Analog stereo audio output x 1
Digital audio outputs x 2, 1 optical + 1 electrical
Output resolutions 480p, 540p, 576p, 720p, 1080i, 640x480, 800x600, 852x480, 1024x576, 1024x768, 1024x1024 ALiS, 1280x720, 1280x768, 1280x1024, 1360x768, 1360x1024, 1366x768, 1368x768, 1400x788, 1400x1050, 1920x1080, 1920x1200, 1080p24sf
Customized output resolution
OTHERS
Backlit remote
RS232 for connecting 3rd party control systems
Infrared In/Out for room-to-room remote control
USB 2.0 for convenient firmware upgrade
CCF file of discrete IR codes is available for easy integration of 3rd party programmable remotes
MPEG1/2/4 decoding
Internal 200GB 7200RPM hard disk
Backlit media player remote is included
100Base-T LAN for media upload/download
Two USB 2.0 ports to attach external hard drives for media storage expansion
PHYSICAL
Dimensions: Without feet:
438mm W x 348mm D x 88mm H (17.2" W x 13.7" D x 3.5" H)
With feet:
438mm W x 348mm D x 98mm H (17.2" W x 13.7" D x 3.9" H)
Standard 19" rackmount ears included
Weight:  8Kg/17.6lbs  9Kg/19.8lbs
Power consumption:  <30W <40W
Power supply: 100-240VAC 50/60Hz auto-ranging
Safety Approval:  CE, FCC, UL[/url]
Ypologizo na kanei giro sta 5000 euro gia tin PRO ekdosi.
Min pairnete tin timi auti kai poli sta sovara, mia provlepsi kano, apo auta pou akouo
ado stin Agglia.
Elpizo na exo ena sta xeria mou se 4 evdomades. Dexetai kai HD apo SDI, pou einai tromero. To PRO exei anavathmismeno clock kai episis Media player me ensomatomeno skliro disko.
Dinato akougetai...
Να ρωτήσω κάτι ως αδαής; Στο επερχόμενο tsunami της HDTV, σε τι χρησιμεύει ένας scaler τέτοιου τύπου;
gkontoletas
trouble in my brain
Από 1080i σε 1080p για projectors και TV με native ανάλυση 1920X1080 και οχι μονο.
Περιμένω τα σχόλια του Βαγγέλη βεβαίως, βεβαίως!!!! :roll: :wink:
Τρομερό μηχάνημα..........
Και μια απλή ερώτηση: σε ένα μηχάνημα Matterhorn (όπως ο δικός μου InFocus 5700) με ανάλυση 1024*576 τι παραπάνω θα μπορούσε να δώσει ένας scaller σαν τον Crystalio????? :roll: :wink:
Βαγγέλης Λάμπρου
Πληροφορήθηκα οτι αυτη τη στιγμή τρέχει συστήματα των Beta testers.
Αυτό το μήνα αναμένονται τα τελευταία ηλεκτρονικά τμήματα για τη σειρα συναρμολόγησης.
Τον άλλο μήνα, από οτι λένε πριν τις γιορτές, αρχίζει η διαθεση.
Φυσικά εφόσον θελήσετε, μπορούμε να κάνουμε presentation στο πρώτο κομμάτι on arrival.
Ετοιμάστε HiDef υλικό και ζεστάνετε 777, 8720, 79 :p
ΑΝΔΡΕΑΣ Κ.
Ιδρυτής
Ειναι στη φωτια και σε περιμενουν :lol:
Βαγγέλης Λάμπρου
Μάλλον Νίκο έχασες κάποια πολύ καλά επεισόδια!
Τι εννοώ;
Κοίτα σε αυτο το Link... http://www.avsite.gr/smf/index.php?topic=12032.0
Εχεις να διαβάσεις....μόλις 8 σελίδες υλικό. :lol:
Το Crystalio II συνδέθηκε ή μάλλον καλύτερα ήρθε συνδεδεμένο με τον Projection Design ActionIII 1080 και το σύστημα έκλεψε τις καρδιές μας.
Περισσότερα δεν μπορώ να σου πω μιας και είμαι ο αντιπρόσωπος, καποια άλλα μελή όμως που είδαν το setup ισως μπορούν να δώσουν κάποιες εντυπώσεις.
Σε περίπτωση που σε ενδιαφέρει μπορούμε να κανονίσουμε κάποιο ραντεβού να το δεις.....in action! :lol:
Ακόμα διαβάζω το forum 2 χρόνια είναι πολλά ...
Το κόστος πάντως είναι απαγορευτικό γιατί εκτός του crystalio πρέπει να έχεις και τα ανάλογα συνοδευτικά ( όσο μπορεί να πει κανείς τον προτζέκτορα και τον player συνοδευτικό ... )
JGmag
