Dali Concept 10 + Concept Center
Πωλούνται λόγω μετατροπής σε καθαρά home cinema από την γνωστή Δανέζικη εταιρεία Dali. Ειναι αγορασμένα πριν από 2 χρόνια και τα χρησιμοποιούσα σε μέτριες προς χαμηλές εντάσεις λόγω διαμονής σε πολυκατοικία.
Τιμή 800 euro.
Απάντηση: Dali Concept 10 + Concept Center
Από το site της DALI για το Concept 10
Concept 10 - Wake Up the Neighborhood
The Concept 10 is a MONSTER of a full-range three-way, floor-standing speaker. Although that might sound like a "living-on-the-edge" or die-hard play-only-loud speaker, it is not.
Yes! The Concept 10 can play LOUD and then some - but playing loud was never our intention with this speaker. We wanted to make a speaker that would be able to give you HI-FI sound AND play loud. And the 2 x 10" bass drivers, 8" midrange and 1" tweeter do just that.
This is a speaker that will give you real DALI high quality sound reproduction at the same time as it will be able to wake up, not just your next door neighbor, but the entire neighborhood - not that we recommend you try - but if you wanted to, you could - and you would still enjoy great sound quality.
Gianni Tab
