Definitive Technology Mythos STS
ΑΝΔΡΕΑΣ Κ.
Ιδρυτής
  • Dimensions5 ½” W x 8 ½” D x 47 ½” H
  • Frequency Response 16Hz-30kHz
  • Efficiency93 dB
  • Nominal Impedance4 – 8 ohms
  • Built-in subwoofer300 watt Digital-Coupled Class D amplifier
  • MSRP $1,499 US,each
Living with the STS in my system for as long as I did, I was awed with the flexibility of music sources, and genres for that matter. As my tastes vary dramatically, I’m happy to report the Mythos handled it all confidently. Especially important and impressive is that ability to reproduce without imposing a signature –guitars sounded full and woodsy without stringy brightness. Horn instruments sound crisp and vibrant, but not raspy or colored. Vocals, both male and female are natural and full without sounding boxy or chesty. The Mythos STS Supertower floorstanding speaker is unique enough to be considered in a class by themselves – rich fine detail, full-bodied mid-tones, and adjustable self-powered bass, in fact considering what you get, these are value-priced speakers. Modest receivers as well as high output amplifiers easily drive the STS’s suggesting an easy integration into most any system – 2-channel, or surround. I really grew to appreciate the nuances and sophistication of the Mythos STS, and would easily be thrilled to keep them around for a long, long time.
http://www.hometheaterhifi.com/two-channel-speakers/549-a-secrets-speaker-review.html
Να μια εταιρεια που πραγματικα εχει αδικηθει στην χωρα μας...
Απάντηση: Definitive Technology Mythos STS
πως να μην εχει αδικηθει
οταν ειχα ρωτησει πριν 3-4 χρονια
μου ειχαν πει παραγγελια και 2400 αν θυμαμαι καλα
ΑΝΔΡΕΑΣ Κ.
Ιδρυτής
Που να ηξερες τις διαφορες στις τιμες που ειχα βρει οταν ειχα
παρει τα δικα μου
Τα πηρα 2100 φθηνοτερα απο την τιμη που μου ειχαν πει...ξερεις που:121:
sunfire
adcom
projection design
miller & kreisel
και την βγαζουμε με στενλες προντακτς
ρε ουστ και θελετε να ασχολειστε και με ηχο εικονα
ΑΝΔΡΕΑΣ Κ.
Ιδρυτής
sunfire
adcom
projection design
miller & kreisel
Πως με πιανεις....:126::126:
aural sound - bass shakers
ξανα ουστ
και εχουν και μια συμπεριφορα
ΑΝΔΡΕΑΣ Κ.
Ιδρυτής
Βεβαια δεν μπορουμε να αμφισβητησουμε πως καποτε ηταν ΤΟ μερος.
Το πρωτο μου Laser Disc απο εκει το αγορασα.
Παντως ειμαι περιεργος.
Εχει ακουσει κανεις Definitive?
ναι, εγώ, και πολύ με αρέσανε.
Όλα όσα άκουσα, εκπληκτικό μπάσσο!
Δυνατά ηχεία, θα τα πρότεινα.
ενας απο τους ναους της 10ετιας των 90s
και εδω και πολλα χρονια θα ελεγα 9+ ειναι ρημαδιο
με τις υγιες σας
Timaras
Δηλαδή έτσι όπως τα λέτε με 4 χιλιάρικα έχεις καθαρήσει από ηχεία ότι μουσική και αν ακούς,είτε τα θες για cinema είτε για μουσική?
Και με τί ενισχυτικό θα τα ταιριάξεις?Το minimum requirement παρακαλώ?
αν μπορεις να δωσεις
4+ χιλιαρκια για 2 ηχεια θε πρεπει να δωσεις και κατι ισοποσο σε ενισχυτη?
λεω τωρα
Εγω παντως εχω ενα ζευγαρακι Mythos, δεν το κρυβω...:126:
Ηχεία τις εταιρείας μπορεί κάποιος να βρεί στην Ελλάδα? Και εάν ναι πού?
Η παίζει μόνο μέσω νετ απ' έξω?
με παραγγελια απο την αντιπροσωπια
και η αντιπροσωπεία ποιά είναι argi???
στο site της Definitive δεν υπάρχουνε στοιχεία για Ελλάδα.
ΑΝΔΡΕΑΣ Κ.
Ιδρυτής
Φαντασου, ουτε οι ιδιοι δεν τους βαζπυν:111::142:
Ε, ωραία, εκείνοι δεν τους βάζουνε, εμείς γιατί δεν τους λέμε???
Κατάλαβα ότι δεν πρόκειται και για ότι καλύτερο... αλλά πείτε να τους μάθουμε και εμείς! ;-)
thx Ανδρέα..... (μου είχανε προτείνει και τα mythos στο τόπικ μου για ηχεία, οπότε ίσως κάνω 1-2 ερωτήσεις εκεί! Πάντα με την επιφύλαξη τον όσων διάβασα εδώ!)
intergrale
