Πωλούνται ο υπόψη συνδιασμός ηχείων σε καινούργια κατάσταση με τις συσκευασίες, χαρτιά και σε εγγύηση.
Τιμή 650€
Τηλ. 6977210589
DEFINITIVE SPECS
Studio Monitor 45
High Performance Shelf/Stand Monitor Loudspeaker
DSS mid/bass driver with Linear Response Waveguide™ for micro-detail and 3D imaging
Second-generation pure aluminum dome tweeter for clearer high frequencies
High-gloss anti-diffraction baffle and shaped enclosures for open, spacious imaging
Crossover network with oversized inductors and Mylar capacitors for amazing sound quality
ON-SHELF MOUNT
Mounting Type
Available Orientations : Vertical
ON-STAND MOUNT
Mounting Type: 1/4 in - 20 Threaded Insert
Available Orientations: Vertical
EXTERNAL AMPLIFIER
Recommended Amplifier Power Per Channel: 20 watts → 150 watts
AUDIO QUALITY
Total Frequency Response: 35 Hz → 30 Hz
Nominal Impedance: 8 ohms
ACCESSORIES
Included Accessories: (4) Bumpers
Optional Accessories: (1) StudioMonitor Stands - Sold Separate
WARRANTY
Cabinet Warranty: 5 years
Drivers Warranty: 5 years
SHIPPING CARTONS
Carton 1
14.69" (37.31 cm) h x 9.69" (24.61 cm) w x 14.75" (37.47 cm) d - 13.5 lbs (6.12 kg)
Orientation: Vertical Height 11.69" (29.69 cm) Width 6.75" (17.15 cm) Depth 11.69" (29.69 cm)
Weight 12.95 lbs (5.87 kg)
SUB SuperCube® 4000
High Performance 1200W Powered Subwoofer With 8" Woofer and Dual 8" Bass Radiators
Huge, accurate bass impact for movies and music from a compact enclosure, measuring only 12.88” x 12” x 13”
8” subwoofer driver pressure-coupled to two 8” Ultra Low Bass Radiators enhances speed, musicality and control
1200-watt digital tracking amplifier and 56-bit Digital Signal Processor (DSP) preamp stage improves performance
Disappearing alpha-numeric display and performance optimizer remote control allow precise system tweaking
Driver Complement
(1) 8" (20.32 cm) d (Round) - Subwoofer
(2) 8" (20.32 cm) d (Round) - Bass Radiator
Height 11.88" (30.18 cm) Width 11" (27.94 cm) Depth 12" (30.48 cm) Weight
45.6 lbs (20.68 kg)
CONTROLS
Display Type: Alpha Numeric (disappearing)
SIGNAL PROCESSING CROSSOVER
Filter: 40 Hz → 150 Hz, Slope of 12 dB per Octave
Phase Settings (Locked): 0°, 90°, 180°, 270°, 360°
INPUTS
Audio Inputs : Stereo Line Level - (2) RCA, Pair (L/R) Analog RCA
Speaker Inputs : (2) Pair of Speaker Cable - na
AUDIO QUALITY
Total Frequency Response: 16 Hz → 200 Hz
INTERNAL AMPLIFIER
Channels: 1
Amplifier Class: Class HD
Primary Protection Circuitry
Multiband Dynamic Range Optimizer (M-DRO)
POWER
US Power Cycle
Singnal Sensitive Auto On/Off
International Power Cycle
Switched & Signal Sensitive Auto On/Off
US Fuse Type
6.2 amp 250 volt Slo Blo
International Fuse Type
4 amp 250 volt Slo Blo
ACCESSORIES
Remote: Performance Optimizer Remote (Included with Subwoofer).
Remote: Type
Infrared: (IR)
Remote Features: Volume +/-, Mute, Night Mode On/Off, Low Pass Filter, EQ, Display, Phase, DSP
Included Accessories: (4) Carpet Spikes
WARRANTY
Electronics Warranty: 3 years
SHIPPING CARTONS
Carton 1
Τιμή 650€
Τηλ. 6977210589
DEFINITIVE SPECS
Studio Monitor 45
ON-SHELF MOUNT
Mounting Type
ON-STAND MOUNT
EXTERNAL AMPLIFIER
AUDIO QUALITY
ACCESSORIES
WARRANTY
SHIPPING CARTONS
Carton 1
SUB SuperCube® 4000
Driver Complement
45.6 lbs (20.68 kg)
CONTROLS
INPUTS
AUDIO QUALITY
INTERNAL AMPLIFIER
Channels: 1
POWER
US Power Cycle
US Fuse Type
ACCESSORIES
Remote: Type
Infrared: (IR)
WARRANTY
SHIPPING CARTONS
Carton 1
135,6 KB Προβολές: 1
