DELL 3008WFP first PC Monitor with DisplayPort
gkontoletas
trouble in my brain
http://www1.ap.dell.com/content/products/productdetails.aspx/3008wfp?c=nz&cs=nzdhs1&l=en&s=dhs
  • High-Definition 30" Panel – Offers ultra-high resolution and superb colour for content-creators, designers, video, gaming and entertainment.
  • 2560 x 1600* Native Resolution – Offers up to 77%* more content compared to Dell 24-inch monitors.
  • 3000:1 Dynamic Contrast Ratio – Produces darker blacks for sharper images, crisp text, better colour saturation and greater detail for HD entertainment.
  • FULL HD 1080P - Supporting the highest video content standards and comes with an HDMI connector.
  • Dell TrueColorTM Technology – 117%* colour gamut for rich, life-like imagery that has accurate colour representation better tones and hues, and supports Adobe 98 colour standard.
  • Extensive Connectivity – Seven connection options: VGA, DVI-D with HDCP, HDMI, S-Video, Component, Composite and DisplayPort give you a wide range of connection options.
  • State-of-the-Art Design – With its brushed aluminum housing, glass stand base, and Dell-patented cantilever arm, the Dell 3008WFP looks as beautiful from the back and side as from the front.
Viewable Size30 inches
Pixel Pitch0.2505 mm
Response Time 8 ms (grey to grey)
Viewing Angle178 degrees
Luminance (Brightness)370 cd/m2
Dynamic Contrast Ratio 3000:1
Horizontal Scan Frequency kHz30 kHz to 94 kHz (automatic)
Vertical Scan Frequency Frequency kHz56 Hz to 86 Hz (automatic)
Optimal Resolution2560 x 16002 at 60 Hz
Preset Display ModesVESA, 720 x 400 – 31.47 kHz Horizontal, 70.0 Hz Vertical, 28.3 MHz
VESA, 640 x 480 – 31.47 kHz Horizontal, 60.0 Hz Vertical, 25.2 MHz
VESA, 640 x 480 – 37.5 kHz Horizontal, 75.0 Hz Vertical, 31.5 MHz
VESA, 800 x 600 – 37.88 kHz Horizontal, 60.0 Hz Vertical, 49.5 MHz
VESA, 800 x 600 – 46.88 kHz Horizontal, 75.0 Hz Vertical, 49.5 MHz
VESA, 1024 x 768 – 48.36 kHz Horizontal, 60.0 Hz Vertical, 65.0 MHz
VESA, 1024 x 768 – 60.0 kHz Horizontal, 75.0 Hz Vertical, 78.75 MHz
VESA, 1152 x 864 – 67.5 kHz Horizontal, 75.0 Hz Vertical, 108 MHz
VESA, 1280 x 800 – 49.7 kHz Horizontal, 60.0 Hz Vertical, 83.5 MHz
VESA, 1280 x 1024 – 64.0 kHz Horizontal, 60.0 Hz Vertical, 108 MHz
VESA, 1280 x 1024 – 80.0 kHz Horizontal, 75.0 Hz Vertical, 135 MHz
VESA, 1600 x 1200 – 75.0 kHz Horizontal, 60.0 Hz Vertical, 162 MHz
VESA, 1920 x 1200 – 74.6 kHz Horizontal, 60.0 Hz Vertical, 193.5 MHz
VESA, 2560 x 1600 – 98.71 kHz Horizontal, 60.0 Hz Vertical, 268.5 MHz
Connector TypeAnalog, DVI-D (Digital) with HDCP, HDMI, S-Video, Component, Composite, DisplayPort
Στα 2.700$
gvts
