DENON 1800BD Blu-Ray
Aυτό ειναι το νέο "εισαγωγικό" Blu-Ray της DENON (1800BD) που αναφερει ο ΗΧΟΣ-ΕΙΚΟΝΑ
Στις ΗΠΑ μπορει κανεις να το βρει απο 570-750 $
http://ecoustics-cnet.com.com/video...d/4014-6463_9-33032315.html?info=write#info-3
Δυστυχως πολλες πληροφοριες δεν μπορεις να βρεις ευκολα... ισως ειναι πολυ νωρις μιας και ειναι
"φρεσκο πραμα"... Γενική ιδεα .... απο http://www.usa.denon.com/ProductDetails/4675.asp
DVD-1800BD
Combining high performance and affordability, the DVD-1800BD player is equipped with the latest technologies to extract the maximum video and audio quality from your Blu-ray, DVD and CD discs, and features support for the latest generation high resolution audio formats, including Dolby TrueHD and Dolby Digital Plus as well as DTS-HD Master Audio soundtracks. For optimum picture quality, the DVD-1800BD also provides a suite of picture adjustment controls that includes brightness and contrast, along with color and sharpness adjustments, and a gamma control for superior deep black and dark gray performance. A growing number of Blu-ray releases include Bonus View picture-in-picture features, which the DVD-1800BD supports. For DVD viewing, the player features precision deinterlacing and upconversion, allowing up to 1080p high resolution via HDMI. For home-made videos on DVD and CD, the DVD-1800BD supports the latest Divx Version 6 codec, and the DVD-1800BD also features a front panel SD card slot for playback of WMA and MP3 music files as well as JPG picture files. For optimum audio fidelity, the DVD-1800BD also features Denon’s Pure Direct mode.
Το περιεργο ειναι οτι αν πας στη σελιδα της DENON με τα χαρακτηριστικά του
http://www.denon.co.uk/site/popup/index.php?p=vergleich_real&Pid=401&vPidN[0]=362
Θα δεις οτι αποφευγουν να δηλωσουν στο τομεα VIDEO SECTION τι τσιπακι εχει .:101:.. απλως οτι ειναι 10-bit
ενω στη ναυαρχιδα τους 3800BD αναφερουν μετα βαιων και κλαδων το 10-μπιτο SXT2 HQV REALTA SILICON OPTIX
Τελος παντων ας περιμενουμε καμμια καλη αξιολογηση απο σοβαρο περιοδικο για να δουμε τι κανει
Βεβαια το κοστος του ειναι υψηλό ... και θα δουμε αν εχει να προτεινει κατι παραπανω απο το PS3
δεδομενου οτι εχει profile 1.1 και αυτο παλι ειναι περιεργο οταν ολοι θελουνε profile 2.0 πλεον
Ειδωμεν
Πιστεύω οτι τα εισαγωγικά μοντέλα της Denon δεν συμφέρουν. Ή τα ακριβά ή άλλη μάρκα πιο προσιτή.
Το "ίδωμεν" γράφεται με "ι". Πτοτρεπτική υποτακτική του "ορώ".
Φιλικά πάντα.
Γιάννης
Πάνε οι εποχές των DVD και blu-Ray άνω του χιλιάρικου, (πχ 3930) , το 3800 πήγε άπατο στις ΗΠΑ. Θα τα παράγουν ίσα-ίσα να βγούν review σε περιοδικά και μετά ...αντίο.
Παντως η συνταγη του 3800 ειναι τελεια... για ποιοτητα... εικονας τουλαχιστον. Τωρα γιατι
η DENON επιμενει να τα βγαζει τοσο ακριβά ... δεν ξερω... Στο τελευταίο HITECH τα σχόλια
ειναι "σουπερ" για τις ικανοτητες του....
Tωρα να αποδιδουμε τα του Καισαρος τω Καισαρι....
Τα κορυφαια μοντελα των player της DENON ηταν παντα στην πρωτη γραμμη και τα σχολια
του διεθνους τυπου ηταν επίσης παρα πολυ καλα. Αυτο να το ξεχωρισουμε απο την τιμολογιακη πολιτικη
της DENON και απο τον εγχωριο τυπο... με τις κουτσουκελες του.
Το 3930 ηταν μακραν αν οχι το καλυτερο DVD-Player στα 2-3 κορυφαια για την ποιοτητα εικονας
που εβγαζε... και η συνταγη του 3800 επίσης κορυφαια... Τωρα γιατι το θελει η DENON κοντα στα 2000 Ε...
αποτελει μεγαλη απορία μας... και ισως τα καταταξει σε αυτα που θα πατωσουν... απο πωλησεις
εκτος αν αυτη ειναι και η θεληση τους... να πουλανε το 1800 και λιγοι να παρουν το 3800...
εαν η τιμη του ηταν κοντα στα 700 θα το επαιρνα χτες !!!
με αυτη την τιμη ουτε καν το σκεφτομαι ...
Παιδες υπαρχει κανεις που να πηρε το DENON 3800 BD ...? για να μας πει εντυπωσεις..??
Δε λέω... πολυ ακριβό... αλλα λεω μπας και το πηρε κανεις και δεν το λεει...:144:
Σε τι τιμες κυκλοφορει στην αγορά....??
Κανενα απο τα μελη μας που σχετιζονται με την αγορά... το ειδαν να παιζει σε εκθεση..?? αποψεις..?? (Ανδρέα...?..:144:)
bmavroeidis
