Denon AVCA1XV
Denon AVCA1XV
Available in Black & Silver
10 channel Equal Power A/V Receiver, featuring Fully Configurable Amplifiers (see table below for some options)
The AVC-A1XV is THX Ultra 2 Certified
10 built-in amplifiers and 16 channels @ 170 WPC/ 8 ohms each
10.1 Channels
HDMI (High-Definition Multimedia Interface)
Dolby Digital and DTS decoding
Dolby Digital EX, Pro Logic IIx decoding with Cinema and Music Modes
DTS-ES Matrix & Discrete 6.1 decoding
DTS Neo:6 Cinema & Music Surround decoding
Dolby Headphone
HDCD Decoder
3rd Gen 1.2Gbps Denon Digital Link for direct connection to to the Denon DVD-3910/5910 for DVD-Audio and SACD
Receives DVD-A Signal through HDMI
Ethernet connection
THX Post processing
RS-232C Upgrade/Control Port
Pure, Direct Mode for Pure Analogue Throughput (Digital Circuits switched off)
1200VA High Current Toroidal Transformer
16 Burr-Brown 192kHz/24bit D.A. Converters in differential mode (2 DACs per channel) with DSD compatibility
192 kHz, 24 bit A/D Converter
2xImproved Hammerhead SHARC Dual 32-bit Floating Point DSP's
Learning LCD Touch screen Remote Included
Denon's Advanced 24-bit AL24 Alpha processing
High Quality 100Mhz component video switching
Variable subwoofer cross-over switching
IEEE 1394 Firewire prepared DSP section, for future upgrade possibilities
Dynamic Discrete Surround Circuit
Video Conversion - Composite to S-Video to Component and down (Interlace only)
Permits DVI video signal input to HDMI video output and vice versa
Faroudja DCDi Scaling (480p/720p/1080i) to Component Output – Main Zone Only
4x Assignable Remote Turn-on Triggers and 3 x Assignable AC Outlet Triggers
True 24-bit/192-kHz Digital Input Capability
Για μένα το τηλεχειριστήριο είναι πανέμορφο.
Τιμή : περίπου 5100Ε σε γαλλικό site που αντιστοιχούν σε 963000 Γιεν ( που είναι η τιμή του στην Ιαπωνία). ή 6000$ περίπου.
Nick Arvanitakis
Audio Pro
Λοιπον με το νεο ετος θα φτιαξω εναν receiver που θα ειναι 15.3 μπας και υσηχασουμε για κανα εξαμηνο!!!
Gebreselassie
Μαύρος!
Νίκο μου κανα μήνα θα ησυχάσουμε, εξάμηνο ούτε για πλάκα.
Οι τύποι είναι άρρωστοι....
Και μόνο που τον κοιτώ δύο πράγματα μου έρχονται στο μυαλό!
1)Το βάρος του (να δω πόσοι έχουν να πάθουν λουμπάγκο..........αλλά και το ράφι τι ζόρι θα τραβά κάθε μέρα!!)
2)Θα μπορέσει κανείς να αξιοποιήσει ΟΛΕΣ τις δυνατότητες του ΠΟΤΕ? Και σε τι software? Στα DVD που νοικιάζουμε? Που ακόμα υπάρχουν εταιρίες που μας δίνουν εικόνα 4:3 & απλό Dolby Surround? :evil:
Μήπως (λέω τώρα εγώ.....) έχουμε ξεφύγει και ακόμα ΔΕΝ το έχουμε καταλάβει?
Με τα λεφτά που κοστίζει παίρνουμε έναν καλό ενισχυτή AV(της τάξης των 1200-1300 ευρώ) + έναν scaler και περισσεύουν και για δικάναλο................
Ε μα κατά κύριο λόγο δεν προορίζεται για ευρωπαϊκές αλλά για την αμερικάνικη αγορά (κάπου το διάβαζα αυτό, τώρα πού δε θυμάμαι)
Gianni Tab
