DENON AVR 4311
TERMATOGAZI
Bass!
http://assets.denon.com/DocumentMaster/UK/product_info_AVR4311.pdf
  • Equal Power Amp Design: Features 9 discrete power amp circuits, and each channel is rated at 140 watts (8 ohms, 20 Hz to 20 kHz, .08% THD). The amplifier section also features the ability to easily handle 4 ohm speakers.
  • Equipped with Denon's high resolution video processor, which accepts standard definition video sources and upconverts them to 1080p HDMI. The latest HDMI 1.4a standard is supported, which provides 3D pass-through (Blu-ray and Broadcast), and also supports Audio Return Channel
  • Equipped with Audyssey's new DSX surround processor, which derives front height and front width channels for a dramatically expanded front soundstage. The Power Amp Assign function lets you specify the precise amplifier and speaker configuration that's right for your home theater setup.
  • Enhanced Network Capability and iPod Connectivity: Lets you listen to Internet radio, play audio files, and display images via an Ethernet connection. The receiver also supports AirPlay, which allows you to stream music wirelessly from an iPhone, iPad, iPod touch, or iTunes
  • Seven HDMI inputs. 3D Pass-Through and Audio Return Channel. FLAC HD Decoding
πωλειται 600 ευρω. στην τιμη συμπεριλαμβανεται και η αδεια για το audyssey pro (150$) και αν η αγορα γινει απο κοντα στην θεσσαλονικη και η μετρηση με το audyssey installer kit.
ο μονος λογος ειναι οτι θελω να παω σε atmos.
ο ενισχυτης δουλευε μονο για τα surround ως ενισχυτης και εδω και ενα χρονο ως pre-amp.
σε χωρο dedicated χωρις καπνο σκονες κτλ.
ztv
