Denon AVR-5805MK2 : Ο τιτανικός των πολυκάναλων!
The AVR-5805MK2 continues the cutting-edge innovations and functionality to achieve our ultimate passion for all receivers – to faithfully recreate the producer’s original intent with absolute fidelity.
Boasting an astounding 170-watts x 10 channels of ultra-clean power and exclusive THX® Ultra2 processing, the AVR-5805MK2 makes the best possible use of all your speakers with the widest variety of entertainment sources. With its ground-breaking multi-room flexibility, the AVR-5805MK2 delivers staggeringly intense, dynamic home theater sound for up to four different sources in four different rooms simultaneously.
To enhance the home theater experience we have added HDMI 1080p switching capability for easy HD viewing. This switching upgrade will allow high end players like the Denon DVD-5910CI, HD or Blu-ray players, or set top boxes with high definition digital signals to be switched and output through the HDMI monitor output port. Also we have added analog to HDMI video conversion in conjunction with the Faroudja video scalar so that non-Macrovision analog video sources can be scaled to 1080p and output through the HDMI monitor port. With the addition of analog to HDMI video conversion, OSD information can now be displayed from most video sources. To keep up with the excitement of Internet music, new Internet radio capability lets you listen to hundreds of possible sources through the Ethernet port on the AVR-5805MK2, using Windows PlaysForSure certified for streaming technology enabling you to control your audio files through a P.C. Web browsing for setup and control has also been included for added versatility.
Our continued dedication to defining technological perfection has led to the incorporation of some of the most critically-acclaimed features for the AVR-5805MK2 – including DDSC-Digital surround processing to provide ultra-precise surround decoding and sound optimization, DENON LINK 3rd Edition input to digitally send DVD-Audio signals through the receiver for musical reproduction of incredible presence and purity, and Auto Setup and Room EQ Adjust to eliminate the hassles of speaker configuration.
Ultimately, the AVR-5805MK2 is a remarkably future-ready receiver that delivers spectacular A/V entertainment today.
Τιμή: $7,000.00
FEATURES
GENERAL
Power Output; Watts Per Channel 170
All Channels Rated @ 0.05 THD
All Channels Rated @ 0.08 THD –
Weight: In Pounds 92
Width (inches) 17.1
Height (inches) 11.0
Depth (inches) 20.5
SOUND MODES
THX Ultra2-Certified
Dynamic Discrete Surround Circuit – D.D.S.C - D ALL NEW
Processor(s) – Bit Depth and Type 32-bit Floating Point
Dolby Pro Logic IIx – with Cinema, Music, Game Modes
THX Post-Processing – DPL (4.0), DPL2 Cinema, DD/DTS (5.1), ES Discrete (6.1), ES Matrix, Neo:6 Cinema All
THX Ultra2 7.1 Cinema, Music and Game Modes
THX Surround EX Decoding
Dolby Digital Surround EX Decoding
dts ES Discrete 6.1 Decoding
dts ES Matrix 6.1 Decoding
dts Neo:6 Stereo-to-Surround Cinema and Music Modes
dts 96/24 5.1 for DVD-Video Processing
Dolby Headphone
HDCD Decoder
Audio Signal Delay (Sync. Audio with Video signal) – By source
Pure Direct/Direct/Stereo Modes on Digital/Analog inputs
Stereo/Direct Modes w/Pure Analog Path
5-Channel Stereo Mode –
Video Game Mode
Wide Screen 7.1 Mode
Mono Movie Surround Mode
Rock Arena Surround Mode
Matrix Surround Mode
Jazz Club Surround Mode
Virtual Surround Mode – For 2 Speakers/Headphones
Multi-Channel Stereo Mode 5/6/7/8/9 Channel
DSP Effect Modes 10
Auto Surround Mode (Analog or Digital Input Type)
Active Center Channel In All Surround Modes
CONNECTIVITY
True 24-bit/96-kHz Digital Input Capability
True 24-bit/192-kHz Digital Input Capability (Denon Link & 1394)
Assignable Digital Inputs
Digital Input – DENON Link 3rd (SACD Ready)
IEEE-1394 Digital Audio Input/Output 2
Digital Inputs: Coaxial 6
Digital Inputs: Optical 6
Digital Outputs: Optical 3
Digital to Analog REC Out
Analog Audio Inputs, Incl. Tuner 15
Phono Input MM type
Source Function Renaming
Analog Record Outputs 5
Front Panel A/V Inputs w/Cover * Composite and S-Video * with Optical In
Video Conversion –Composite to S-Video to Component Main and Second Zone
Video Conversion – Composite to S-Video to Composite
Video Conversion – Analog to HDMI *New
DVI/HDMI Video Inputs – Compatible with 1.1 Spec. – Multi-Channel Audio *1080p HDMI 1/5 *Now HDMI with 1080p
HDMI Video Outputs *1080p 1 (Plus 1 DVI) *Now HDMI with 1080p
Composite Video Inputs 8
Composite Video Outputs 4 Plus Mon/Z2/Z3
S-Video Inputs 8
S-Video Outputs 4 Plus Mon/Z2/Z3
Component Video Inputs x Bandwidth - *Assignable *6 x 100MHz (1 BNC)
Component Video Outputs 2 (1 BNC) Main Zone, 1 Second Zone
6-Ch. External Analog Input EXT IN 2
8-Ch. External Analog Input EXT IN 1 - 10 ch
Banana Plug Speaker Terminals, All Channels High Grade
Cinema EQ
Front A/B Speaker Selector –
56 Station Auto-Preset Memory Tuning
Radio Data System (RDS)
XM Satellite Radio 'Connect and Play' Ready – with optional antenna –
Direct Function (Tone Bypass)
Volume Control Un-muting
Selectable Muting Levels (Full/-40/-20)
Video Select Control
RS-232 Port – Third Party Remote Controllers
RJ-45 Ethernet Port – Same Functionality as AVR-5805/4806
PC Setup and Control Capability
IR Serial Remote In/Out terminals
+12v Trigger Output - Assignable 4/250mA
Multi-Source/Multi-Zone (*Uses REC OUT) 4 Source/4 Zone Audio; 3 Source/3 Zone Video
Pre-amp Outputs for Multi-Zone
High Pass Filter for Multi-Zone Outputs
Multi-Zone Pre-Amp Outputs – Selectable Output Levels
Discrete Multi-Zone Composite Video Output - *S-Video also *
Discrete Remote Power On/Off, Source Selection and Volume for Main and Second/Third* Zones *
Discrete Remote Source Selection for Zone 3 –
Assignable Amplifier Configuration of Surround Back Channels –
Speaker Time-Delay and Level Controls: L/R, Sub, C, Surr. L/R, Surround Back
Pre-Amp Outputs Z1 - 10 / Z2 - 6
Internet Radio
iPod Port (Using optional AKP-100 cable) –
iPod Dock Control Port (Using optional ASD-1R Denon iDock) –
USB Flash Drive Port –
COMPONENT TECHNOLOGY
Equal Power Amplifiers 10 ch
Low Impedance Drive Capability
High-Current/Discrete Amplifiers
Independent Power Supplies 6
Pure Audio Construction –
Toroidal Power Transformer
Dolby Digital, dts and DSP Modes – Analog Devices, HammerHead SHARC x1 Second Zone
Dolby Digital, dts and DSP Modes – Texas Instruments Aureus x3 for Main Zone
AL24 Processing - All Channels –
24-bit/192-kHz DACs – Burr-Brown PCM-1791 2 per 16 Channels
24-bit/192-kHz DACs - Analog Devices –
Analog-to-Digital Conversion - Bit Depth/Sampling Rate 24-bit//192kHz
Variable High/Low Pass Crossover Points (12/24dB) 40/60/80/100/120/150/200/250
Built In Time Based Correction
CONVENIENCE FEATURES
Front Panel A/B Speaker Selector –
Auto Setup Calibration
Auto/Manual Room Equalization
Audyssey MultEqxt Room Eq. with up to eight position setup
Auto Setup Microphone Included/Type N/Optional Alum DM-S305
Dual Surround Mode Spkr. Selector
Icon-Based On-Screen Display
Front Panel System Setup Control
Personal Memory Plus
System Setup/Surround Parameters Lockout
Relay-Controlled Protection Circuits
Microprocessor User Re-set
Detachable Power Cord
Subwoofer Peak-Level Limiter (THX)
Pre-programmed (10 Devices) Glow Key Remote Control with Punch Through Commands –
Pre-programmed/Learning EL Remote with Backlighting and Punch Through Commands Y/RC-995
lakiss51
Φιλε Johnny αυτο το θηριο θελει ...θηριοδαμαστη!!! ποιος θα το "ξεζουμισει" ομως;
Πάντως αυτό που βλέπω είναι ότι σε λίγο καιρό για να ρυθμίσεις και να "παίξεις" με κάτι τέτοια θηρία θα πρέπει να έχεις περάσει από εντατικά σεμινάρια :). ΑΑλλιώς "βούλιαξε το βαπόρι" :D
Δεν μπορω να καταλαβω ποιος ειναι ο λογος που βγαινουν τετοιες συσκευες εκτος απο τον εντυπωσιασμο.Ειναι προτιμοτερη η λυση μιας μοναδας με τον ιδιο εξοπλισμο αλλα σε εκδοση προενισχυτη και να μπορει ο αγοραστης να επιλεξει τα ενισχυτικα που θελει (πολυκαναλο τελικο,συνδυασμο δικαναλων ή μονοπλοκ).Αλλωστε υπαρχει και πρακτικο προβλημα,ειναι ασηκωτα!
Συμφωνώ με τον tanto. Προσωπικά με τα λεφτά αυτά θα πήγαινα σε προ/τελικό. Όσο τέρας και να είναι ο πολυκάναλος, ε ξεχωριστοί τελικοί θα κάνουν καλύτερη δουλειά όπως και να το κάνουμε. Κρίμα τα λεφτά για μένα να πάνε σε τέτοιο ολοκληρωμένο μηχάνημα.
1200 ευρω κοστιζει η αναβαθμιση απο A1XV σε A1XVA ( η 5805 σε 5805 mk2 αν προτιματε).Πλακετες μολις παρεληφθησαν.Αυριο τον πηγαινω.
Ομως στο Αμερικα η denon εδειξε ηδη για Δεκεμβρη τον 5805ci με πιο εξελιγμενο audyssey (32 σημειων).Και καποια στιγμη του χρονου θα εχουμε HDMI 1.3.
Δεν τελειωνει το βασανο.
Αλλα και η απολαυση ειναι μοναδικη.
Ελπιζω μονο η Denon να συνεχισει τις αναβαθμισεις
Παντως σε κανενα δε θα λειψει καποια εισοδος.
Ο μετασχηματιστης ομως μαλλον καπως μικρος για τον ογκο του ενισχυτη
Δημήτριος Φάβας
