Another feature added for 2016 is support for the new Audyssey smartphone app. As Audyssey Pro is phased out, this app will provide many of the same features in an easier to use fashion, making it accessible to consumers as well as custom installers. The app will guide the user through the Audyssey calibration, using the included Audyssey microphone for auto-calibration. The app will also allow the user to check correction results, set target sound options, adjust frequency roll-off, set mid-range compensation controls and save/load/view/print results. The new app will be available from app stores in October for a cost of €19.99, which is considerably less than the old Audyssey Pro kit.
ολα σε ενα .!!!
στα 2500e
