DENON DVD 1920
σε αριστη κατασταση.Universal player με HDMI και upsumpling στα 1080i k 720p.Τιμη πωλησεις στα 190 ευρο
FEATURES
Availability Current
Cosmetic Finish –
Equal Power Amplifiers –
DVD-Video
DVD-Audio
Super Audio CD
Music/Video CD/CD-R/CD-RW Playback No Video CD
DVD-R/RW Video
DVD+R/RW Video –
Kodak Picture CD Compatible
Fujifilm Fujicolor CD Compatible
JPEG Photo-File Viewer
WMA9 Playback
Single Disc Play
Multi-Disc Play –
Progressive Scan
DDVC – Dual Discrete Video Circuitry
DCDi™ by Faroudja Progressive Scan Decoding Engine
Noise Shaped Video™- Interlace and Progressive –
3:2 Pull down Detection
Chroma Upsampling Error – Chroma Bug No
DPIC – Denon Pixel Image Correction –
10-bit, 27MHz Analog Devices Video DAC (480i) –
10-bit, 54MHz Video DAC (480p) –
10-bit, xxMHz Video DAC (480i/480p) 11-bit/216MHz
Dual, Discrete 12-bit, 216MHz Analog Devices Video DACs (480i/480p) –
Dual, Discrete 14-bit, 216MHz Analog Devices Video DACs (480i/480p) –
Super Sub Alias Digital Filter
Buffer Memory to decrease Layer change 2MB
Multi-speed DVD-ROM Drive - 2X for DVD, 4X for CD 1.5x/4x
Burr-Brown 24/192 Audio DACs (DSD/PCM Discrete) PCM-1738
Burr-Brown 24/192 FL/FR, 24/96 C/SL/SR/Sub –
Digital Bass Management for DVD-Audio/MLP/SACD, High (12dB) and Low Pass (24dB) with Speaker Configuration/Level Control and Delay Time Control 80Hz* No Delay control for SACD
HDCD Decoder –
Built-In Dolby Digital, dts, DVD-Audio, SACD* Decoders with 5.1 outputs
WMA 9 (Audio only), MP3 Audio Decoder for CD-R/RW, DVD-R/RW Discs
Mosquito, 3D, Block, Noise Reduction Adjustments –
Picture Mode Adjustments
4:3 Aspect Ratio Shrink and Zoom Adjustments for 480p *Available on HDMI/DVI Outputs Zoom
Pure Direct Modes (User Selectable - Video/Digital/Display Off) –
Composite Video Output
S-Video Output
Component Video Output
Coaxial and Optical Digital Outputs
Parallel Digital/Analog Audio Outputs
Parallel Video Outputs
IEEE-1394 Audio Outputs (PCM/DSD compatible) –
True 24-bit/96kHz Digital PCM 2-Ch. Output *24/192 on DLink, IEEE-1394
HDMI 1.1 (HDCP Compatible – SiL9030) - With Selectable Scaling – 480p/720p/1080i/*1080p and DVD-Audio Output
DENON Link SE – Proprietary digital, fully balanced output of DD/dts/DVD-Audio/PCM/SACD* –
DVI-D (HDCP Compatible) - With Selectable Scaling – 480p/720p/1080i -
Black Level Adjustment
Passes Below Black for Monitor Calibration
Discrete Power On/Off
RS-232C Port for Third Party Controllers –
Remote I/O Ports
Auto-Power Off
On-screen Display
Disc Exchange during Play –
Virtual Surround Sound
Lock Drawer Mode (Store Demo)
Front Panel Construction Plastic Mold
Weight (Pounds) 5.72
Width 17.1"
Height 3.0"
Depth 12.2"
UP,παιδια υπαρχει ακομα!!!Δεν νομιζω να υπαρχει κατι καλυτερο στα λεφτα αυτα
s channel
