DENON DVD 1920
Σε αριστη κατασταση. Universal player με HDMI και upsumpling στα 1080i k 720p.
Τιμη πωληση στα 130 €
FEATURES
Availability Current
Cosmetic Finish –
Equal Power Amplifiers –
DVD-Video
DVD-Audio
Super Audio CD
Music/Video CD/CD-R/CD-RW Playback No Video CD
DVD-R/RW Video
DVD+R/RW Video –
Kodak Picture CD Compatible
Fujifilm Fujicolor CD Compatible
JPEG Photo-File Viewer
WMA9 Playback
Single Disc Play
Multi-Disc Play –
Progressive Scan
DDVC – Dual Discrete Video Circuitry
DCDi™ by Faroudja Progressive Scan Decoding Engine
Noise Shaped Video™- Interlace and Progressive –
3:2 Pull down Detection
Chroma Upsampling Error – Chroma Bug No
DPIC – Denon Pixel Image Correction –
10-bit, 27MHz Analog Devices Video DAC (480i) –
10-bit, 54MHz Video DAC (480p) –
10-bit, xxMHz Video DAC (480i/480p) 11-bit/216MHz
Dual, Discrete 12-bit, 216MHz Analog Devices Video DACs (480i/480p) –
Dual, Discrete 14-bit, 216MHz Analog Devices Video DACs (480i/480p) –
Super Sub Alias Digital Filter
Buffer Memory to decrease Layer change 2MB
Multi-speed DVD-ROM Drive - 2X for DVD, 4X for CD 1.5x/4x
Burr-Brown 24/192 Audio DACs (DSD/PCM Discrete) PCM-1738
Burr-Brown 24/192 FL/FR, 24/96 C/SL/SR/Sub –
Digital Bass Management for DVD-Audio/MLP/SACD, High (12dB) and Low Pass (24dB) with Speaker Configuration/Level Control and Delay Time Control 80Hz* No Delay control for SACD
HDCD Decoder –
Built-In Dolby Digital, dts, DVD-Audio, SACD* Decoders with 5.1 outputs
WMA 9 (Audio only), MP3 Audio Decoder for CD-R/RW, DVD-R/RW Discs
Mosquito, 3D, Block, Noise Reduction Adjustments –
Picture Mode Adjustments
4:3 Aspect Ratio Shrink and Zoom Adjustments for 480p *Available on HDMI/DVI Outputs Zoom
Pure Direct Modes (User Selectable - Video/Digital/Display Off) –
Composite Video Output
S-Video Output
Component Video Output
Coaxial and Optical Digital Outputs
Parallel Digital/Analog Audio Outputs
Parallel Video Outputs
IEEE-1394 Audio Outputs (PCM/DSD compatible) –
True 24-bit/96kHz Digital PCM 2-Ch. Output *24/192 on DLink, IEEE-1394
HDMI 1.1 (HDCP Compatible – SiL9030) - With Selectable Scaling – 480p/720p/1080i/*1080p and DVD-Audio Output
DENON Link SE – Proprietary digital, fully balanced output of DD/dts/DVD-Audio/PCM/SACD* –
DVI-D (HDCP Compatible) - With Selectable Scaling – 480p/720p/1080i -
Black Level Adjustment
Passes Below Black for Monitor Calibration
Discrete Power On/Off
RS-232C Port for Third Party Controllers –
Remote I/O Ports
Auto-Power Off
On-screen Display
Disc Exchange during Play –
Virtual Surround Sound
Lock Drawer Mode (Store Demo)
Front Panel Construction Plastic Mold
Weight (Pounds) 5.72
Width 17.1"
Height 3.0"
Depth 12.2"
Κωνσταντίνος Παντός
