DENSION HardDisc Car MP3p
Simple installation. Simple operation.
Massive music capacity.
The Dension DH100ix head unit is optimised for mass storage MP3 playback from industry-standard hard disks. Use with either the Dension DMP3C compact slot-in 2.5” hard disk or the Dension DMP3A high-capacity 3.5” hard disk MP3 players for huge music storage with simple data transfer via IDE or USB2.0 from your PC or Mac.
The large LCD display makes it easy to navigate your MP3 collection via the DH100ix cursor pad. You can select from 16 preset display/keypad colours to match your car interior and even configure your own custom colour for a perfect match. Playback display formats can be customised with the included DMP3 Manager software which even lets you add your own startup/shutdown logo.
The display includes an easy to use music browser and customisable playback display with ID3 tag data of albums, artists, etc., VUMeters, elapsed/remaining time.
Music playback features include repeat, random and:
AlbumPlay – the ability to go to the start of the folder in which the currently playing track is stored – great for use in random mode
MyRadio – user-defined custom random-weighted playlists accessible from the 1-6 keys.
Seamless track transitions – unlike many MP3-compatible CD/Tuners, Dension products feature near instant track to track transitions which is great for lovers of dance mixes.
Moodlogic – if you use Moodlogic – you can browse music through a Moodlogic database view and create “instant mix” playlists. It’s like having a virtual DJ in your car.
DH100ix is compatible with the Sony RMX2S/RMX4S wired remote joystick. You can also use the Connects2 range of factory-fit/Sony stalk adaptors to let your vehicle’s steering wheel controls or column-mounted audio controls as input devices for DH100ix.
Specifications
RDS FM Tuner with 3 x 6 presets
4x35W power output
4 channel pre-out
176 x 64 pixel LCD display with 16 backlight colour options
Telephone mute
Standard ISO connectors for simple installation
Tilt down, removable front panel
Power antenna
Sony RMX2S/RMX4S compatible
Σκληροί δίσκοι
Advanced music features.
Dension DMP3C is a compact slot-in 2.5" hard disk MP3 player designed for quick and simple installation with the Dension DH100ix head unit.
DMP3C uses industry standard 2.5” 4200RPM IDE hard drives and fully supports drives with capacities greater than than the 137GB ATA limit as well as content stored on SmartMedia Card.
MyRadio – user-defined custom random-weighted playlists. The first six MyRadio or standard .m3u playlists stored on the player correspond to the 1-6 buttons on the Dension DH100ix head unit.
Seamless track transitions – unlike MP3-compatible CD/Tuners, Dension products feature near instant track to track transitions which is great for lovers of dance mixes.
Moodlogic – if you use Moodlogic you to browse music through a Moodlogic database view and create “instant mix” playlists. It’s like having a virtual DJ in your car.
Dension DMP3C includes DMP3 Manager software for full player configuration, an AC adaptor and 3.5mm stereo audio output for standalone use and high speed USB2.0 interface. You can simply drag&drop music from your PC or Mac onto the DMP3A using standard Windows Explorer or Mac Finder tools.
DMP3 manager
Powerful customisation of your Dension DMP3 hard disk MP3 player
Dension DMP3 Manager, included with every DMP3 hard disk MP3 player, is a PC-based application that allows you to fully customise your Dension MP3 player.
DMP3 Manager comprises six editors:
MyRadio
The MyRadio editor allows you to build playlists for your DMP3. Unlike sequential .m3u or .pls playlists (which the DMP3 of course supports), MyRadio playlists are random playback-based, but allow you to definte both the files and folders selected, together with the random probability weighting of each entry - a great way of building genre- or mood-based playlists.
When combined with the DMP3 series AlbumPlay feature that lets you listen to the entire folder containing the currently playling track, MyRadio represents a great way of accessing your music. On LINK compatible head units, the first six MyRadio or .m3u playlists saved on your DMP3 correspond to the 1-6 keys on your head unit.
PlayDisplay Editor
You can build your own customised playback display screen format including ID3 information, timers and VU Meters for full control of your DMP3 player's user interface.
Logo Editor
Create your own startup/shudown logo for your player by importing from .jpeg or .bmp image files.
Config Editor
Enables creation of complete sets of player settings (e.g. equaliser, repeat mode, key function) for rapid access from the DMP3.
Message Editor
You can build your own user interface labels for the DMP3 to translate or customise interaction with the player.
Online Update
Staying up to date with the latest DMP3 firmware and DMP3 Manager software is simple. DMP3 Manager lets you check current software status and download any required updates.
Θέλουν να μας πουν ότι η βελόνα του σκληρού θα αντέξει στους ελληνικούς δρόμους; Πλάκα μας κάνουν;
Σπύρος Μπλάτσιος
Διακεκριμένο μέλος
η τεχνολογία των σκληρών έχει βελτιωθεί σε θέματα αντικραδασμικότητας (μην ξεχνάμε ότι συσκευές τύπου ipod χρησιμοποιούν τους σκληρους δίσκους κατά κόρον) αλλά φυσικά για τους Ελληνικούς δρόμους ένα test drive θα μας πείσει!!!
Σε τελική ανάλυση, αν κάποιος έχει κανα Rallye (ή Saxo) με 4ποντα ελατήρια και αμορτισέρ.....κούτσουρα, ό,τι και να του βάλεις θα χαλάσει.........
Και με RadioCdp ΔΕΝ θα ακούει γιατί απ' τον κραδασμό το laser θα χορεύει κλακέτες!!!
Είναι πάντως μια πολύ ενδιαφέρουσα λύση.
Και γλυτώνουμε τα CD από σκόνες/ζέστη/ήλιο/υγρασία και το κουβάλημα και το βάλε/βγάλε του γεμιστήρα στο CDchanger (που θα είναι και στο πόρτμπαγκάζ.....)
Καλή περίπτωση.
Να μάθω και τιμή και ενημερώνω............. :roll:
Θα δω και άλλες τεχνικές λεπτομέρειες (όπως πχ πόσες εξόδους προενίσχυσης έχει κ.ο.κ) για να ξέρουμε τι άλλο καλό κρύβει η συσκευή!!
Πολύ καλή και έξυπνη κίνηση είναι που συνεργάζεται η πηγή με το joystick της SONY (Sony RMX2S/RMX4S ) και έτσι θα μπορεί κάποιος που έχει συνηθήσει σε SONY να το χρησιμοποιήσει εύκολα. :idea:
Και από την άλλη, πάντα θεωρούσα το joystick της SONY το καλύτερο (και πιο εύχρηστο) χειριστήριο για πηγή στο αυτοκίνητο......Και μάλιστα με πολύ μεγάλη διαφορά από οτιδήποτε άλλο κυκλοφορεί στην αγορά........ :D :D
Όντως, κύριε Δημητρόπουλε μάθετε τιμή, αν και συνεχίζω να διατηρώ επιφυλάξεις για την αντοχή του...
Το σκέτο Γιάννης είναι αρκετό!!(γράψε μας και το δικό σου........ :wink: ). Μια παρέα είμαστε!
Θα το κοιτάξω αυτές τις μέρες πάντως το θέμα της τιμής της πηγής αλλά και το κόστος των σκληρών δίσκων!
Το σκέτο Γιάννης είναι αρκετό!!(γράψε μας και το δικό σου........ Wink ). Μια παρέα είμαστε!
Ok, σκέτο Γιώργος και για μένα, :) έτσι κι αλλιώς την ίδια περίπου ηλικία έχουμε (το Μάιο κλείνω τα 30).
Μερικές φωτογραφίες από το Ελληνικό site
Αυτή είναι η black έκδοσή του......(προτιμώ την silver/μπλε φωτισμό)
Έρχονται σαν
1) DH-101 Silver / DMP3-C no HDD + USB 2.0 Cable + AC Adaptor, Program CD (κωδικός DH11-00)
2) DH-102 Black / DMP3-C no HDD + USB 2.0 Cable + AC Adaptor, Program CD (κωδικός DH12-00)
3) DH-101 Silver / DMP3-C 20GB + USB 2.0 Cable + AC Adaptor, Program CD (κωδικός DH11-20)
4) DH-102 Black / DMP3-C 20GB + USB 2.0 Cable + AC Adaptor, Program CD (κωδικός DH12-20)
Τιμές δεν μπόρεσα να βρώ εκεί.
Θα προσπαθήσω να επικοινωνήσω μαζί τους!
Αν και το Ελληνικό site είναι χμμμμ............ :?
Δυστυχώς!
Παιδιά καλημέρα,
Ίσως να ξέρετε ότι στο αυτοκίνητό μου έχω εγκατεστημένο ένα iPod, αυτό που έχω διαπιστώσει μέχρι τώρα, είναι ότι σε θέματα κραδασμών είναι ιδιαίτερα ανθεκτικό και δεν μου έχει τύχει να χοροπηδήσει, όπως μου έχει τύχει σε απλό cd.
Πιστεύω ότι οι συσκευές με σκληρό δίσκο είναι ποιο ανθεκτικές και έχουν καλύτερη αντικραδασμική προστασία από τα απλά player.
Και αν Δημήτρη συνυπολογίσουμε ότι το iPOD δεν είναι εντελώς σταθερά στερεωμένο (όπως πχ η πηγή στο ταμπλό) πιστεύω ότι θα δουλεύει καλά........
Ευχαριστούμε για την πληροφορία.......... :D
Πλάκα, που μπορεί να πάθει κανείς στα καλά καθούμενα!!!
Τις προάλλες, μπήκα στο site της εταιρίας που φέρνει το συγκεκριμένο μηχανάκι στην Ελλάδα ( www.digitalhellas.com ) και είχα γράψει ότι ήταν χμμμμ..........
Δεν υπήρχε τηλέφωνο, παρά μόνο η διεύθυνση και μερικές φωτογραφίες.
Ξαναμπήκα σήμερα για να στείλω e-mail ώστε να με ενημερώσουν για τις τιμές αλλά και για όλα τα προιόντα τους.
Και..........έκπληξη!!
Η σελίδα έχει αλλάξει ριζικά (προς το καλύτερο) και όλα δείχνουν πιο οργανωμένα.
Θα επικοινωνήσω μαζί τους, και θα κοιτάξω (αν έχω και τιμές ακόμα καλύτερα) να σας ενημερώσω για όλα τα προιόντα τους! :D
DH100-ix
http://www.digitalhellas.com/index_files/Page646.htm
· Accepts removable DMP3-C player
· Multi-color LCD display
· RDS AM/FM radio
· Intuitive interface for navigation and control of MP3 playlists and tracks
Product Summary
SKU/Item Number: DH10-00 (includes DH unit and DMP3-C with no hard drive)
SKU/Item Number: DH10-40 (includes DH unit and DMP3-C and 40GB drive)
SKU/Item Number: DH10-A1 (includes DH unit and DMP3-A1 Silver no hard drive and CarHost)
SKU/Item Number: DH10 (includes DH head unit for use with DMP3-C or DMP3-A)
Price: 385.86 Euro (DH10-00),
                     531 Euro (DH10-40),
                     464 Euro (DH10-A1),
                     265.5 Euro (DH10)
All prices include VAT at 18%
DMP3-C
· Accepts standard 2.5 inch IDE hard drives for laptops
· Works as personal MP3 player when used with the provided power supply
· USB 2.0 compliant for fast read/write
· Win 98/2000/XP supported
· Headphone jack
SKU/Item Number: DMP3C-00 (no hard drive)
SKU/Item Number: DMP3C-40 (with 40GB hard drive)
Price: 194.7 Euro (DMP3C-00), 339.84 Euro (DMP3C-40)
Prices include VAT at 18%.
Kit includes USB 2.0 cable and AC adapter
Tιμές βρέθηκαν.
Μένει μόνο να λάβω e-mail από κάποιον υπεύθυνο της εταιρίας (η απλά να γράψουν κάποιο post εδώ.....) για κάποια πιο επεξηγηματική απάντηση.
Οι τιμές ακούγονται λογικές, αρκει να ξεκαθαριστεί το συνολικό ποσό και τι ακριβώς συμπεριλαμβάνεται στην τιμή.............
Αυτά!!!
intergrale
