Devialet analog/pwm hybrid
deleted user 10898
http://www.devialet.com/index.php
D-Premier, EISA best product 2010-2011
September 03, 2010
The European Imaging and Sound Association (unique association of 50 special interest magazines from 19 European countries) has awarded Devialet's first product - the integrated 2x240 amplifier D-Premier - as the high end audio product of the year: "From France comes the most innovative and advanced amplifier to emerge on the hi-fi scene in years.
deleted user 10898
MAXIMUM POWER: 2x240W
Speaker impedance range: 8 to 2 Ω — highly compatible with the loudspeakers on the market
D/A Converter T.I. PCM 1792 — perfect play back of all your digital sources
THD+N at full power: 0.001% — purity and fidelity of the timbers
IMD SMTPE: 0.001% — high definition of complex sounds
SNR: 130 dB unweighted — zero noise
Thermal distortion: unmeasurable — integrity of the sound relief
Output impedance < 0.001 Ω — bass control and global accuracy
2* phono inputs MC/MM — for turntables
2* RCA analog inputs — for CD, DVD, or portable digital players…
2 TOSLINK® optical inputs — for CD, DVD, or portable digital players…
4* RCA S/PDIF digital inputs — for CD, DVD, or portable digital players…
1 XLR AES/EBU digital input — for professional sources
1 HDMI® 1.3 input & 1 output — for HD formats, SACD, BLU-RAY players, HD TV…
1* RCA analog/digital 2.1 output — for subwoofers
4 universal loudspeakers output terminals
1 RS-232 port — home automation
1 trigger input & 1 ouput — for chained components, external remote ir flashers/sensors
Internal IR sensor — compatible with universal remote controls
180 DPI Color screen
1 SD card slot — for the configuration of the amplifier
Configuration through user friendly interface — Simple and flexible use
600W Switched-mode power supply
Efficiency > 85% — low power consumption
Sleep mode power consumption: < 5W
* over a total of 6 configurable RCA connectors
Overall dimensions: 400x400x44.5mm
deleted user 10898
HiFinews April2010 review
http://www.devialet.com/download/hifi2010.pdf
ADH - Analogue/Digital Hybrid - amplifier technology is an entirely proprietary
regimet κλπ διαβαστε το... και εξηγηστε μου...
μα καλα, εχουν εναν μικρο Class A που "κατευθυνει" ή κατ άλλους "διορθώνει" τον class D ?
διορθωστε με ΠΑΝΑΓΙΑ ΜΟΥ πριν ερθει ο κωσταυτιας...
hatzopou
