Τι γίνεται με το Dieselgate? Διάβαζα αυτό: https://analyst.gr/2020/04/10/dieselgate-i-germaniki-apati/
Most visitors online was 3430 , on 7 May 2025
“The five car manufacturers Daimler, BMW, Volkswagen, Audi and Porsche possessed the technology to reduce harmful emissions beyond what was legally required under EU emission standards.
“But they avoided competing on using this technology’s full potential to clean to higher standards than what is required by law.”
"The Commission is breaking new legal ground with this decision, because it is the first time it has prosecuted technical cooperation as an antitrust violation," the company said in a statement. "It is also imposing fines even though the contents of the talks were never implemented and customers were therefore never harmed," it added.
Και μετά θα πάρει σειρά η Απω Ανατολή....όσο πάνε οι Γερμανοί γίνονται όλο και περισσότερο 'Ελληνάρες', στο τέλος θα 'φαγωθούνε' μεταξύ τους και θα ολοκληρωθεί η 'μεταμόρφωση'
Ναι, εταιρείες που ανταγωνίζονται μεταξύ τους. Πρωτόγνωρο.όσο πάνε οι Γερμανοί γίνονται όλο και περισσότερο 'Ελληνάρες', στο τέλος θα 'φαγωθούνε' μεταξύ τους και θα ολοκληρωθεί η 'μεταμόρφωση'
DEF technology has been used for decades in the country in agriculture, industrial and large scale power generation applications. The concept is the same across the board: the urea mixed with heat creates ammonia that causes a chemical reaction that reduces NOx by 70%-95%. In fact 90% of urea production is used as nitrogen-released fertilizer. It is important to note that automotive-grade urea is of a much higher grade purity than fertilizer urea. If a lower grade fertilizer urea is used in automotive engines you risk disintegration of the SCR and possible ruin the engine. It may even trigger ECM sensors to incorrectly prompt a DEF Tank Empty warning.
Διάβασε ξανά τι έγραψα, όταν η Merc πρόσθεσε AdBlue ξεκίνησαν οι ερωτήσεις.Μιλάμε γι αυτό που 'έδωσε΄τους άλλους για να βγει 'λάδι'
