Disc Demodulator Maranz CD-400B CD-4
geoli
Πολύ σπάνιο. Πωλείται σε πλήρη λειτουργία και εξαιρετική κατάσταση με το Manual του.
Τιμή 220 Ευρω
The Marantz model CD-400B is a simple to operate demodulator for obtaining four discrete channels from CD-4 records.
The unit incorporates an automatic noise reduction circuit to minimize record noise without affecting frequency response, and an automatic 30Hz carrier level control which selects the optimum carrier level for the cartridge being used.
Non CD-4 records may also be played through the CD-400B without affecting their performance.
The controls do not have to be adjusted to play non CD-4 records; when they are played and the mode switch is in the 4 CH Auto position, the Radar indicator will illuminate and the record will automatically be demodulated into four discrete channels.
Marantz Model CD-400B CD-4 Disc Demodulators. A CD-4 demodulator is required to play CD-4 encoded vinyl discs. If you own a Marantz 4 channel receiver, any model, you need this accessory to play CD-4 records. This demodulator will work with any 4 channel receiver or amplifier, and will work with any high quality phono cartridge. Switches: Power
Selector: Phono/Aux
Mode: 4-CH Auto/2-CH Indicators: Power
Carrier Radar Rear Panel: 2-CH Direct Out (R, L)
Phono (R, L)
Aux Front (R, L)
Aux Rear (R, L)
4-CH Out Front (R, L)
4-CH Out Rear (R, L)
Separation Control Left
Separation Control Right
Carrier level
opanamas
