Dreambox DM500s
Powerful receiver for digital TV and Radio programs.
Technology that inspires ..
you'll be amazed!
- 250 MHz IBM PowerPC Processor (350 Mips)
- Linux Operating System
- 1 x Smartcard-Reader
- MPEG2 Hardware decoding
- Common available NIMs (DVB-S, DVB-C)
- V.24/RS232 Interface
- 100Mbit full duplex Ethernet Interface
- 2 LED status
- unlimited channel lists for TV/Radio
- channel-change time < 1 second
- full automatic service scan
- supports directly bouquet-lists (indirect unlimited)
- supports EPG (electronic program guide)
- supports multiple LNB-Switching control (supports DiSEqC)
- fully adaptable OSD in many languages (skin-support)
- SPDI/F Interface for digital bit stream out (AC-3 / DTS)
- 1 x Scart-interfaces (fully controlled by software)
Product | DreamBox DM500 technical data
DBS-Tuner:
Frequency Range 950 …. 2150 MHz
Signal Level - 65 dBm …. - 25 dBm
Signal-to-Noise Level 12 dB max.
DBS-Tuner Input Connector F-Type female
Input Impedance 75 Ohm
AFC +/- 3 MHz
Demodulation Shaped QPSK
Input Symbol rate 2 …. 45 Mbaud/s, SCPC / MCPC
FEC Viterbi and Reed-Solomon
Viterbirate 1/2, 2/3, 3/4, 5/6, 7/8, automatic assimilation
Roll-off Factor 35 %
Demultiplexing according ISO 13818-1
Video decoder:
Video Compression MPEG-2 and MPEG-1 compatible
Video Standard PAL G/ 25 Hz
Video Formats 4:3 / 16:9
Footage 16:9, automatic assimilation for 16:9 TV-Device (over Scart)
Letterbox precolating for 4:3 TV-Device
Audio decoder:
Audiokompression MPEG-1 & MPEG-2 Layer I and II
Audio Mode Dual (main/sub), Stereo
Frequency: 32 kHz, 44.1 kHz, 48 kHz, 16 kHz, 22.05 kHz, 24 kHz
Output analog:
Output Level L/R 0,5 Vss on 600 Ohm
THD > 60 dB (1 kHz)
Crosstalk < -65 dB
Output digital:
Output Level 0,5 Vss on 75 Ohm
Sampled Data Filtering 32 kHz, 44.1 kHz, 48 kHz
S/PDIF-Output optical (AC3)
Video parameter:
Input Level FBAS 1 Vss +/- 0.3 dB on 75 Ohm
Teletext filter in conformity with ETS 300 472 Standard
TV-Scart:
Output: FBAS,RGB,S-VHS over OSD selectable
Serielle Interface RS 232:
Typ RS232 bidirectional
Bitrate 115,2 kBit/s max.
Plug Connector SUB-D-9
Function Update of Firmware and Preprogramming
Ethernet:
100 MBit compatible, bi-direktional interface
LNB Power and polarisation:
LNB Current 500mA max. ; short-circuit-proof
LNB Voltage vertical < 14V without load, > 11,5V at 400mA
LNB Voltage horizontal < 20V without load, > 17,3V at 400mA
LNB shut-off at Standby-Mode
Count of active satellite position:
DiSEqC 1.0/1.2 SAT POSITION / SAT OPTION
DiSEqC - Rotor Control
Power consumption:
< 10W / 12V
Input voltage:
DC12V,alternating acurrent +/- 15%
Extern power supply:
Input:
110-240V AC / 50-60Hz / 0,6A
Output:
12V = / 1A
Physical specification:
Ambient Temperature +15°C...+35°C
Humidity < 80%
Size (W x D x H): 195 mm x 130 mm x 40 mm
Weight: 0,6 kg
Και το μικρό στο μάτι μοντέλο της Dreambox κάνει την δουλεία εξίσου καλά. :wink:
Από το περασμένο Σάββατο αντικατέστησε και με το παραπάνω τον αναλογικό ComCrypt!
Ααα.. και με την αγορά πήρα και μια κάρτα δώρο για τα κανάλια υψηλής ευκρίνειας xplus και inxc TV :lol: :lol:
Μα αυτή η εταιρεία είναι σε καθεστώς χρεωκόπησης...
Επίσης, μπορείς να δεις HD σε MPEG2? Με τέτοιο CPU? Έχει άλλο ειδικό chip επάνω;
Δεν το ξέρω αυτό αλλά και δεν το νομίζω, όταν τον παράγγειλα χρειάστηκε να περιμένω και λίγες μέρες μέχρι την νέα παραλαβή γιατί τα αποθέματα εξαντλούνται πολύ γρήγορα. :wink:
Αμα βρω πού το διάβασα θα το γράψω. Αλλά με το HD decoding τι γίνεται; Το κάνει; Γιατί από ότι ξέρω κανένα Dreambox δεν το κάνει ακόμα...
Αν κάτσω από τώρα να σκέφτομαι τις μελλοντικές μεταδώσεις υψηλής ευκρίνειας χάνοντας αυτό που μπορώ να έχω τώρα…
panosop
Συστημικός
Παιδιά ο δέκτης είναι ενας απλός δέκτης DVB-S χωρίς ιδιαίτερες δυνατότητες , πέραν του ότι εχει και μπορεί να φορτώνει images για διάφορους εκπαιδευτικούς λόγους.
Τέτοιες δυνατότητες μπορούν να τις κάνουν πολλοί άλλοι δέκτες στην αγορά.
Δεν εχει φυσικά HD, αλλά για χρήση απλής δορυφορικής είναι καλός...
Μερικά πλεονεκτήματα και μειονεκτήματα του δεκτή δίχως να το έχω ψάξει σε βάθος.
Απουσία RF εξόδου ιδιαίτερα χρήσιμο αν θέλουμε λήψη σε όλες τις τηλεοράσεις του σπιτιού. Προσωπικά έλυσα το πρόβλημα με εξωτερικό modulator RF.
Συγκριτικά με το μεγαλύτερο μοντέλο δεν κάνει εγγραφή σε σκληρό δίσκο.
Παραπλήσια ποιότητα ήχου και εικόνας με το ακριβότερο μοντέλο. Δεν διεκδικεί δάφνες σε αυτόν τον τομέα αλλά είναι ισορροπημένο και δεν ενοχλεί η ξενίζει καθόλου αν συνδεθεί στον πολυκάναλο ενισχυτή.
Πολύ καλύτερη λήψη δίχως διακοπές σε σχέση με τον Humax 5400Z που σε βροχή άνεμο και συννεφιά κάνει παρά πολλές διακοπές παρόλο που το κάτοπτρο μου δεν φημίζεται για την σταθερότητα του.
Δυνατότητα με software να κάνει εγγραφή σε ποιότητα MPEG-2 στο PC.
Και τέλος έχει το μεγάλο πλεονέκτημα ότι με τις κατάλληλες συνθήκες λειτουργίας μέσα σε ελάχιστους μήνες να κάνει απόσβεση της αξίας αγοράς του και όχι μόνο.
Τον πήρα 130 λίρες Κύπρου αλλά κυμαίνεται ως 150-160.
Προσωπικά δεν ασχολήθηκα ιδιαίτερα μαζί του αφού κάτι φίλοι ανάλαβαν τα επιπλέον file που χρειαζόταν για σύνδεση στο internet. Βασικά εγώ τον βρήκα στυμμένο και μου εξήγησαν μόνο ορισμένα βασικά σημεία που έχουν να κάνουν με την σύνδεση στο internet.
epidi askoloume kapio diastima me ton singikrimeno dekti tha anafero kapia leptomeria.
proton apo thema ikona to 500raki me ton 7020 i 7025 den exi kamia sxesi,safos xiroteri ikona.
omos mporoume na kanoume to eksis
vazontas ton ip tou ston mozila kai patontas enter mas vazi sti selidatou .pou apo eki mporume na alaksoume kanalia .
prin apo afto tha zitisi user kai pass
user-root
pass- dreambox
afto isxi gia ola ta modela dreambox ektos kai an kapios exi alaksi to pass
pantontas to control mas pai se enan alon pinaka,patontas to screeen shot mas vgazi foto apo afto pu pezi ekini tin stigmi sto dream.
ean exoume vali to programa vlc sto pc kai patontas eki pou lei vlc kai me ligo psaksimo na vroume to vlc.exe kai vazontas to hd forum pou vriskete sto hotbert mporoume na doume tin ikona hdtv mpeg2 sto pc, oso afora gia ikona se mpeg4 den tin anigi.
koskef
