Dreamvision Dreamweaver Plus
Model DreamVision DreamWeaver Plus
Projection system New Texas Instruments Mustang HD2+TM 12° LVDS DMD
Enhancement New Faroudja DCDi TM FLI2310
Optic Carl Zeiss Projection Lens: F/1.9,26.7 - 36.8mm focal length
Color Wheel 7 segments (RGBRGBG), 5 x (9000rps, 300Hz, 6500K color
temperature)
Resolution 1280x720 16 :9
Contrast Ratio 2300:1 full on / full off
Lamp 220 Watt UHP (3000 hours life time)
Brightness 1200 lumens
Dual light output mode with High Bright mode (+20%)
Colors 16.7 millions simultaneously displayable
Installation Front, Rear, Table, Ceiling (Ceiling bracket in option)
Keystone Correction Digital up to +/- 20° vertical, +/- 9° horizontal
Inputs 2 x components - gold RCA
1 x Component - 15-pin D Sub
2 x S-VHS - Mini Din 4-pin
1 x Composite Video - RCA
1 x DVI - M1-DA VESA
1 x HDTV Analog - 15-pin D Sub
1 x RS232 control - 9-pin D Sub
1 x IR Repeater (Niles / Xantech compatible) - 3.5 mm mini-jack
2 x 12 V trigger - 3.5 mm mini-jack
1 x USB
1 x Power supply
Video Compatibility Component and RGB HDTV (720p, 1035i, 1080i, 1080p)
Component EDTV (480p, 576p progressive scan), SECAM: M,
Component, composite and S-Video standard video.
(480i, 576i, 576i RGB SCART with adapter, NTSC, NTSC M
4.43, PAL: B, G, H, I, M, N)
Size Ø439 mm - High 127 mm
Weight 4.4 Kg
Audible Noise 25 dB
Accessory Learning Remote Control capable of controlling up to 10
different others electronic devices.
Option Ceiling bracket horizontally and vertically adjustable in white
or black finish.
Color option Silver, White or Black
DreamWeaver Plus
Specifications
Silver Finish
White Finish
Black Finish
Είδα τα χαρακτηριστικα του και νομίζω οτι είναι ένας πολύ ενδιαφέρον προβολέας. Τί λέτε κύριε ΑΝΔΡΕΑ Κ.; Γνωρίζετε πότε θα έρθει Ελλάδα και σε ποια τιμή;
ΑΝΔΡΕΑΣ Κ.
Ιδρυτής
Γεια σου Klaster,
πρεπει να σου πω πως και εμενα μου φαινεται πολυ ενδιαφερων ο εν λογω βιντεοπροβολεας,ιδιαιτερα εαν συνυπολογισεις το γεγονος πως εχω απολυτη εμπιστοσυνη στην σειρα Dreamweaver.
Εδω, σε αντιθεση με τα προηγουμενα μοντελα, παρατηρω διαφορες σε σχεση με τους "ανταγωνιστικους" Infocus 7205 και Toshiba MT-800.
Αναμενομενη τιμη γυρω στα 6900€ και κατω,εαν θελει να κτυπησει τον ανταγωνισμο.
Ημερομηνια αφιξης στην χωρα μας δεν γνωριζω, και αυτο εξαρταται ουσιαστικα απο την αντιπροσωπεια.Θα ελεγα μεσα στο φθινοπωρο.
Ευχαριστω κυριε ΑΝΔΡΕΑ. Νομίζω πως είναι πολύ καλός και δελεαστικότατος οσον αφορά στο ντιζάιν του για να τον έχεις στο σαλόνι σου.
Είμαι μεταξύ αυτού και του BENQ 8720+ που θα εμφανιστη και αυτός το Νοέμβριο.
Αναμονή λοιπον!
kokdim
