DS 3.0 for AzBox HD
DS 3.0 for AzBox HD
Image per FLASH
+ CVS Enigma2 2010.11.01
+ Kernel v. 2.6.19.19-The Ripper
+ BusyBox v1.6.3
New mapping of Buttons:
+ BLUE Button - EmuManager
+ LONG BLUE Button - Extensions
+ YELLOW Button - Timeshift
+ LONG GREEN Button - Subservices (NVOD)
+ GREEN Button - DS GREEN PANEL
+ AUDIO Button - Audio Selection
+ TEXT Button - Videotext
+ RED Button - DS Single EPG ( DM 8000 )
+ HELP Button - DS QuickButton
!!! THIS FIRMWARE DOES NOT INCLUDE ****, NOT EMULATORS, NOT URLS FOR DOWNLOADING
ILLEGAL STUFF OF ANY TYPE. ONLY WITH ORGINAL DREAMCRYPT SUPPORT!!
!!! DS IS NOT RESPONSIBLE IN ANY WAY FOR WHAT THE USERS WILL DO WITH THIS
FIRMWARE.
InfoBar
- Lite zapping skin
- Orbital Position
- Active EMU in Skin
- Active Cryptinfos in Skin
- SNR & AGC & BER in Skin
- Provider name in Skin
- Video Resolution in Skin
- Fr, SR, Pol, Fec Info in skin
- Decoding Source
- Display Multi-audio and Teletext on OSD
- Caid in Skin
- Provider ID in Skin
- Date in Skin
- Ecm Time
- Hops
- Source
- **** Name
- Picon
- Permanental Clock
- Date format
DS Extras
- Swapfile Manager
- Mount Manager -> NFS/CIFS
- File Manager - here you can manage your files in set-top-box
+ play movies, pictures, music
+ run scripts
+ view files
+ install tar.gz/tar.bz2/ipkg
+ create new folder / new file
+ create symlinks
+ remove directories / files
+ rename files
+ move files
+ change permissions of file ( ex. chmod 755 )
+ sort files by name /date
+ POBIERANIE NAPISOW NAPI-PROJEKT - w koncu Polski projekt
- Added Kernel Modules Manager
+ USB Mouse/Joystick/Keyboard
+ SCSI Generic
+ WLAN
+ USB cardreader ( PL2303 and FTDI )
+ ISOFS
+ SMB/CIFS
+ CDFS
+ UDF
+ VFAT
+ NTFS
+ SMBFS
+ HFS
- Devices Manager - here you can see your HDD/SD/CF/USB/DVD - mount/unmount, setup, get informations
- Daemons / Services Manager - here you can start/stop/reload and setup daemons such as:
+ Inadyn ( dynamic DNS updater )
+ HTTPD ( little apatch )
+ UPnP Client / Server
+ SyslogD and KlogD
+ NFS Server
+ Cron
+ Dropbear
+ Samba
+ OpenVPN
+ Avahi ( mDNS / DNS-SD daemon )
- Decoding Setup
+ Show DsemuD informations?
+ Show No free tuner info?
+ Show Tune failed info?
+ Show No data on transponder info?
+ Show Service not found info?
+ Show Service invalid info?
+ Show Zap-Errors?
- Blue LED brightness manager
- SmartScript - /usr/scripts/*_smartscript.sh
- Stream Advanced informations
+ PAT info
+ CAT info
+ NIT info
+ SDT/BAT info
+ EIT/TOT/TDT info
+ PMT info
+ ECM info
+ Help
- System Information
+ Free Ram Memory
+ Free JFFS2 Memory
+ Free Flash Memory
+ Free HDD Memory
+ Free USB Memory
+ Free CF Memory
+ Running Processes
+ Active internet Connections
+ View and Clear Timer Log
+ Lan settings info
- Emu Manager
+ Reset CS
+ Reset EMU
+ Reset Both
+ Filecheck ( pressing RED button on EmuManager you can see, that all files are on right place, then emu can start )
+ DSemud Info ( information about started daemons )
+ Extended informations for:
- CCcam Center
- GBox Center
- MgCamd Center
-QuickButton Tool
Choose function which will appear on HELP button:
- Management Addons
- Smart Script Tool
- System Informations
- Stream Advanced Information
- Inadyn Setup
- Decoding Setup
- Emu Extended
- Emu informations
- Kernel informations
- Enigma2 Config informations
- Processes Manager
-DS Addon Manager
+ author, description, size, picture functions to see info about addons.
+ Informations + Picture by pressing RED in Addon Manager
It is up to the enduser to add them should he wish to use this image other
than with a legal subscription card.
The DS TEAM is NOT responsible for any unauthorised use of this firmware.
!!! THIS FIRMWARE DOES NOT INCLUDE ****, NO EMULATORS, NO URLS FOR DOWNLOADING
ILLEGAL STUFFS OF ANY TYPE. ONLY WITH ORGINAL DREAMCRYPT SUPPORT!!
FIRMWARE.
HOME FORUM:
www.dsteam.cwispy.com
Please report ALL bugs here
κατεβαστε το απο
http://hotfile.com/dl/79844968/cda51..._new2.rar.html
Evasound
