H 0204 είναι ο διάδοχος της πετυχημένης 0202. Έχει ένα έξτρα ζεύγος 34bit εξόδων και βελτιωμένη ηχητική ποιότητα. Όπως διατείνεται ο Marketing Manager της εταιρείας:
“The outputs have a signal to noise ratio of 117dB with 0.0008% distortion. The numbers speak for themselves. Specifications like these usually cost $1000 and up.”
[RELIOPS="Τεχνικά Χαρακτηριστικά"]The E-MU 0204 USB 2.0 features:
Premium 24-bit/192kHz A/D and D/A converters * (A/D: 113dB SNR, D/A: 113dB SNR) delivering you a pristine recording/capture and playback experience
Ultra-low noise Mic/Hi-Z/Line preamplifiers with ground lift switches enable you to record microphones, keyboards or guitars directly into your computer delivering professional results (XLR, 1/4” TRS, and 1/8” 5V condenser mic input)
Ultra-low latency USB drivers offer accurate timing and playback of your recorded audio and expressive control of your software instruments
Independent headphone DAC path to enable separate playback and cueing for DJ applications
Hardware zero-latency direct monitoring (mono/stereo) allows you to record and overdub with no timing delays
Plug-and-play operation with hands-on control of all major functions like direct monitoring level, headphone level, and preamplifier gain to streamline your creative process
Driver compatibility with most popular audio/sequencer applications letting you work with your choice of tools - (Windows XP (SP3 or greater), Vista/x64, Windows 7/x64:ASIO2 and WDM; Macintosh OS X (10.5 or greater): Apple CoreAudio)
I/O Configuration:
Class-A Ultra-low Noise Mic/Hi-Z/Line Preamp XLR, 1/4" TRS and 1/8"* Inputs (113dB SNR)
Class-A Hi-Z/Line Preamp 1/4" Input (113dB SNR / 0.0008% THD)
Two 1/4" Outputs (117dB SNR / 0.0008% THD)
1/8" Stereo Speaker Output (117dB SNR)
Stereo Headphone Output which doubles as an assignable pair of auxiliary outputs (117dB SNR / 0.0008% THD)[/RELIOPS]
ΤΙΜΗ : $130
Επίσημο site
I/O Configuration:
ΤΙΜΗ : $130
Επίσημο site
