EagleBox 800 HD & EagleBox Mini HD.
Απάντηση: EagleBox 800 HD & EagleBox Mini HD.
Χαρακτηριστικα.
EagleBox 800 HD DVB-S2 – PVR
This is a new HD DVB-2 with CA solution . It can support MPEG4, H.264,AVC and so on. USB,Vedio,MP3, JPEG and PVR can be available by external USB and HDD or the Disk shared in LAN.
Main Feature
 MPEG-Fully DVB-S / DVB-S2 MPEG4/H.264 HD/SD compliant
 Ethernet supported, LAN 10/100 Mbps Ethernet
 HDMI supported
 1 embedded CA slot
 Video resolution for 1080i,1080p 720p, 576p, 576i
 Software & Channel Database Transfer via USB, or the Disk shared in LAN.
 8000 channels programmable
 Channel switching time less than 2 second
 True-color On-Screen Display (OSD)
 Full Picture In Graphic (PIG) function
 EPG , Subtitle and Teletext( via VBI and Software) supported
 Program and Channel information transfer from receiver to receiver
 Exciting games embedded(Future support)
 S/PDIF for digital audio DiSEqC 1.0, 1.1, 1.2 and USALS
 Software update via USB, or the Disk shared in LAN.
 Time Shift and Video Recording Via external USB or HDD, or the Disk shared in LAN.
 Powerful Multi Media Player Function:Avi,Asf,DivX,Dat,Flv,Mkv,Mov,Mpg, Rm/rmvb,Vc,Wmv,Wma,Xvid,(Rm/rmvb,Wmv,Wma… Some format can be supported in future support)
 Support mp3 play with picture showing backgroud(music album).
 Support DHCP and static IP setting.
 powerful network function :access the files on PC with Linux OS working with Samba(simple IPTV)
Enables video online such as website( www.youtube.com )
 Support BitTorrent download
 External wifi Supported
 Ip for weather forecasting , stock
 Be compatible with I-pod (Future support )
Technical Specification
MPEG Decoding Transport Stream &Profile Level Mpeg-4,H.264,Mepg-2 MP@HL,MPEG/AVC
Input Data Rate 120Mbit/s Max
Video Format 576i,576p,720p,1080i,1080p
Audio Decoding MPEG1 Layer I&II,Mpeg2, MPEG4 AAC and MPEG4 AAC-HE (AAC+),Dolby Digital(AC-3),MP3,WMA
Audio Mode Left, Right, Stereo
Sampling Freq 32,44.1,48,96Khz
Demodulator Demodulation QPSK/8PSK S2
Symbol Rate 2~45MS/s
Outer Decoder RS(204,188,8)
Code Rate 1/2,2/3,3/4,5/6,7/8
Tuner Input Frequency 950MHz to 2150MHz
Input Impendence 75 ohms
Input Level -65dBm to -25dBm
Input Socket F type connector
LNB Power H:18V,V:13V,Max 500mA
Output Connector SCART TV (CVBS,RGB)
HDMI HD Video/Audio ,Ver1.2,Type A
CVBS 3xRCA
Digital Audio 1xRCA
USB 2.0 host
Data Trans Ethernet 1XRJ45
RS232 Male 9pin
Main System CPU 240MHz,BGA
Flash 64M Byte
S-Dram DDR1 2X64M,Byte
General Supply Voltage 100~240VAC 50/60Hz
Power Consumption 25 watts Max
Standby Power 1 watts max.
Operation Temperature +5°C to +40°C
Storage Temperature -20°C to 70°C
Dimension 250mm X175mmx38mm
EagleBox Mini HD DVBS2 – PVR
This is a new revolution for HD DVB-2 with CA solution. It is mini which can be sticked behind of led. But it is with full function for FTA+CA+USB+PVR+AV+RS232
Main Feature
 MPEG-Fully DVB-S / DVB-S2 MPEG4/H.264 HD/SD compliant
 Ethernet supported, LAN 10/100 Mbps Ethernet (optional)
 HDMI supported
 1 embedded Conax CA slot
 MINI SIZE
 Video resolution for 1080i,1080p 720p, 576p, 576i
 Support explorer function , e.g face book(optional)
 Software & Channel Database Transfer via USB, or the Disk shared in LAN.
 8000 channels programmable
 Channel switching time less than 2 second
 True-color On-Screen Display (OSD)
 Full Picture In Graphic (PIG) function
 EPG , Subtitle and Teletext( via VBI and Software) supported
 Program and Channel information transfer from receiver to receiver
 Exciting games embedded(Have not supported)
 S/PDIF for digital audio DiSEqC 1.0, 1.1, 1.2 and USALS
 Software update via USB, or the Disk shared in LAN.
 Time Shift and Video Recording Via external USB or HDD, or the Disk shared in LAN.
 Powerful Multi Media Player Function:Avi,Asf,DivX,Dat,Flv,Mkv,Mov,Mpg, Rm/rmvb,Vc,Wmv,Wma,Xvid
 ,(Rm/rmvb,Wmv,Wma… Some format can be Future support)
 Support mp3 play with picture showing backgroud(music album).
 Support DHCP and static IP setting.
 External wifi
 Ip for weather forecasting , stock
 External RS232 ,AV and IR
 Be compatible with I-pod (Future support)
CVBS 3xRCA
Digital Audio 1xRCA
USB 2.0 host
RS232 Male 9pin
Main System CPU 300MHz,BGA
Flash 64M Byte
Dimension 140mm X45mmx25mm
Οι φωτο ειναι απο το original firmware.
Με το patch θα υποστηριζει :
Cccam, Newcamd, Ecam, Avatar κτλ. - Third part s/w
Κυκλοφορησαν οι 2 δεκτες και patch γι' αυτους.
Σε λιγες μερες,θα γραψω και μερικα πραγματα για media player δυνατοτητες,blind scan, 4:2:2 , δυνατοτητες στο δορυφορικο κομματι ........
Eaglebox HD Patch 11/11/11
Added support for BISS keys identified by PID
http://www.multiupload.com/DEL5PO7NW0
George Markop
