EISA AWARDS 2011-2012
Nelsy
Ιεράπετρα
European Video Projector 2011-2012 - JVC DLA-X7
European Blu-ray Player 2011-2012
- Sony BDP-S780
European HT Subwoofer 2011-2012 - Sunfire SDS-12
European HT Receiver 2011-2012 - Pioneer VSX-921
Αναλυτικά όλα εδώ
Nick Arvanitakis
Audio Pro
Απάντηση: EISA AWARDS 2011-2012
Πάλι το τσίμπησα το awardακι...
Και μάλιστα double!
European Loudspeaker 2011-2012 - JBL Studio 190
Striking from the first glance, JBL’s ‘Weave’ design ensures its Studio 190 floorstander will stand out from the crowd. This three-way loudspeaker, which includes a pair of 165mm bass units, sounds powerful, dynamic and detailed, offering a great insight into all types of music – including movie scores. Crucially, while the Studio 190 has an exotic appearance, it remains easy to drive and is the ideal partner for a great many entry-level amplifiers and AV receivers. So much loudspeaker, so small a price tag – how does JBL do it?
http://www.eisa.eu/awards/1/audio-home-theater.html
European In-Car Innovation 2011-2012 - JBL MS-2
JBL engineers offer a simple answer to the million-dollar question: “What button should I press to make my factory fitted car radio sound like a professionally installed system?” The JBL MS-2 is a compact, truly unique portable device designed to enhance the sound of any portable audio source before it is fed into the auxiliary input of your car stereo. A built-in microphone and sophisticated digital circuitry analyze and correct the sound of your car stereo within 10 seconds. Suitable for use with any portable device, you simply have to press the “magic button” to dramatically improve the way your car sounds.
http://www.eisa.eu/awards/2/in-car-electronics.html
αναμενομενα θα ελεγα.....αυτα τα ηχειακια της bw πως θα τα βαλουμε στο γραφειο μας?
ΑΝΔΡΕΑΣ Κ.
Ιδρυτής
Βρε παιδια, γιατι εαν εχεις δει μια φορα τα αποτελεσματα της EISA...δεν χρειαζεται να τα ξαναδεις?:121:
Απλα παρακολουθεις ποια νεα μοντελα εχουν βγει και...τα ξερεις απο πριν.
hm , κανα δυο μηνες πισω , τετοιες μερες 2002
Η jamo παρουσιαζει το πρωτο σετ της κατα thx u2
Το ηχειο με μοναδες πανακριβες , αντοχη υποδειγματικη στα γκαζια,
πλην των χαμηλων(και αυτο κουβεντιαζεται ) τρελλα γεματο παντου.Το ηχειο σηκωνει το κυπελακι ειζα.
Λιγους μηνες πιο πριν το γιαμο (παρουσαση στον ηχο 6/02 πρωτη πανευρωπαικη παρουσιαση ) παρουσιαστηκε το φοβερο και τρομερο teufel thx u2.
Ok το ηχειο δεν ειχε την ποιοτητα κατασκευης του δεναζικου jamo, αλλα εκτελουσε ισωπεδωσεις all over.
H teu δεν σηκωσε ποτε κυπελακι, αλλα στην καρδια των οσων ειχαν ακουσει τα πρωτα teu ειναι παρεα με τα mk , ισως τα καλυτερα σετακια που παρουσιαστηκαν ποτε.
Αληθεια δωσαν ποτε κανα κυπελακι σε ονομα b class σαν την τεου ?
Nelsy
Ιεράπετρα
Πάντως Ανδρέα στους προβολείς παρατηρώ ότι από το 1997 που 'μπήκαν' στα βραβεία με τον Philips ProScreen 4500:116:,υπάρχουν εννιά εταιρείες που κέρδισαν τα αντίστοιχα βραβεία-δεν είναι και λίγες...
Philips-Jvc-Sony-Yamaha-Epson-Infocus-Panasonic-BenQ-SIM
koskef
