Emerald Physics CS3
deleted user 10898
Our controlled directivity technology minimizes interaction between the speaker and your listening room to allow you to hear the recording as it was intended.
παντου λεει τα θετικα της "ανοιχτης μπαφλας" αλλα πουθενα δεν λεει οτι τα διπολα θενε και μια αποσταση απο τον πισω τοιχο 1.5 μετρακι η πολυ "πειραγμα" του πισω τοιχου...
με αρεσουν παντως...
deleted user 10898
Eliminating the Room
Emerald Physics has developed a method to control a speaker’s dispersion pattern in order to minimize room interactions and thereby eliminate most of the room’s sonic signature. Our patent-pending BDC (Broadband Directivity Control) technology is a turning point in the history of loudspeaker design. Until now, speaker / room interaction has been one of the major problems in home audio systems. Conventional speakers have wide dispersion and an omnidirectional pattern in the bass range, sending large amounts of sound energy toward the room boundaries, which are reflected back into the listening space with a time delay. These are known as early reflections, which color the sound of the original signal. The omni-directional bass pattern also excites room resonances in all three axis which tends to cause the boomy, ill-defined bass commonly experienced in many systems. The solution is to create a speaker with a more narrow dispersion pattern as well as a more consistent dispersion angle across the frequency spectrum. Listening to mainly the loudspeaker’s direct field eliminates most of your room’s sound, creating a consistent and natural playback performance even in difficult rooms.
deleted user 10898
δεν λεει φυσικα τιποτα γιατι....ειναι πατεντα... τι ολα θα στα πουνε?
Απάντηση: Emerald Physics CS3
όχι βρε, είναι απλό, τα δίπολα συμπεριφέρονται πιο φιλικά στο χώρο απ'ότι τα "κουτιά".
αλλά έχει και DSP το πακέτο, οπότε πιθανά να κρύβει κι εκεί εκπλήξεις...
πάντως δεν είναι δα και τόσο ακριβό.
deleted user 10898
νομιζω οτι εχουν κανει καποια "πατεντα" στην σχεδιαση του ομοκεντρικου? ηχειου.
ειπα εμενα με αρεσουν...
οσο για τα διπολα, στο σπιτι του κρεμασμενου...
Gianni Tab
