Emotiva MPS-1 Seven Channel Power Amplifier
Σπύρος Μπλάτσιος
Διακεκριμένο μέλος
επτακάναλος τελικός με μόνο $2000???
κι όμως είναι αλήθεια!!!
ο Emotiva MPS-1 είναι ένας θηριώδης τελικός με 7x200w ισχύ και τιμή χώμα!!!
πωλείται μόνο μέσω internet και factory direct!!!
Χαρακτηριστικά
* Audiophile quality, modular power amplifier.
* True card cage design can accommodate up to seven 200 watt (@8 ohms) mono block power modules - power modules glide in and out on Nylon rails
* 200 watt power modules feature independent 350VA, low noise toroid power transformers w/ high speed rectifiers and 48,000uF of storage per channel for a 336,000uF total, across seven independent channels
* High efficiency Class H power amplifier design, minimizes power losses and allows cool operation
* Complementary, discrete power amplifier design incorporating high current, high speed, Toshiba power devices
* Truly transparent, integrated soft clip circuitry
* Balanced XLR and RCA inputs
* Channel status indicators for standby, operate, and fault
* THD less than .015%, 20Hz-20kHz with 80kHz measurement bandwidth
* DC offset, less than 1mv, servo controlled.
* Completely Stable into 2 ohm loads
* 200 watts/8 ohms - 300 watts/4 ohms - 400 watts/2 ohms *minimum* - seven channels driven, mains limited
* Frequency response 20Hz-20kHz +/- 0.1 dB, or 10Hz-100Khz +/- 3dB
* Signal to Noise Ratio - 100dB, un-weighted
* Crosstalk between ANY channels -greater than 120dB
* Input impedance - 20k ohms.
* Fully protected from all fault conditions with ultra quiet, module mounted, fan assisted cooling for severe duty cycle applications
* Soft start circuitry. Silent turn on/off - No audible transients
* Signal sensing auto turn on or remote trigger. Soft touch power switch
* All aluminum capacitors are premium quality, low ESR, 105°C rated for high reliability and performance.
* Doubled sided, plate through, glass epoxy, FR4 PCB's used throughout with 2 ounce poured copper on all power sections and ground planes
* Modules are designed for field replacement with the removal of four screws
* 5RU chassis with floating multi-element, milled aluminum faceplate. Indirect cobalt blue illumination of all controls and main panel
* Black lacquered, piano finished wood side panels are included, as are milled aluminum rack ears for professional installations
* Massive, multi element milled aluminum faceplate with "floating" wing detail - indirect, cobalt blue panel illumination with panel dimmer
* Power consumption during standby - 3 watts or 60 watts at idle
* IEC power inlet, 120/230 VAC user configurable on modules
* 5 year warranty
* Weight - 115 lbs.
* Dims: (HxWxD) 7 11/16" x 18 7/16" x 18 13/16"
costasgera
