Κώστας Φ.
Empirical Audio Pace-Car ($1100 on up depending on configuration) is a very flexible architecture reclocker that can be used with USB, Wireless audio servers, some PCI cards and even Transports.
Nicknamed the "Swiss Army Knife" of reclockers, the Pace-Car reduces the jitter from various streaming audio devices. The Pace-Car is available in two configurations, called "Types". Type One is for Wireless Music Servers, PCI cards or Transports that can accept a "Master Clock", "Word Clock" or "Bit-Clock" input. Type Two is for two input systems or USB-type systems where the source clock is fixed or based on frequency synthesis or software generation. The current version 2 Pace-Car PC board only interfaces to I2S DACs, including the Benchmark DAC-1 with Empirical I2S interface, Northstar 192, Northstar Extremo, Perpetual Technologies P-3A, Audio Logic. and DEQX with Empirical I2S interface. Version 3 Pace-Car PC board also has S/PDIF or AES output, allowing it to interface to any DAC. The S/PDIF or AES interface will add a small amount of jitter, which may be audible, depending on your components and cables. Sample rates include 16-bit/44.1 kHz, 24-bit/96 kHz, and 24-bit/192 kHz.
The Pace-Car uses a FIFO-memory (First-in, First-out) to temporarily store the audio streaming data. The clock writing the data into the FIFO is independent from the clock reading the data out of the FIFO. The output clock, which is the critical one can be selected from Superclock4 (one or two), low-jitter monolithic oscillator (one or two), Ultraclock, or an external clock of your choice. Connections to the Pace-Car consist of Empirical I2S bus, S/PDIF coax and AES/EBU XLR
enjoythemusic.com
