emu tracker pre usb 2.0
Αγορά από την Ελλάδα
Πώληση λόγω αναβάθμισης 90euro
Pristine 24-bit/192kHz A/D and D/A converters (A/D and D/A: 112dB measured SNR performance) deliver unmatched USB audio fidelity for pristine audio quality
Preamplified analog signals are available before the A/D converters, allowing the Tracker Pre to be used as a standalone high-quality stereo microphone preamp (using optional power supply)
Hardware zero-latency direct monitoring (mono or stereo) with continuously variable level control]
Plug-and-play operation with hands-on control of all major functions like direct monitoring level, headphone level, preamplifier gain and more
Independent ground lift switches for optimal audio fidelity/flexibility
USB bus powered (can also be powered using optional 5V power supply)
Cross-platform support (Mac OS X and Windows XP32/XP64/Vista32/Vista64) and compatibility with most popular audio/sequencer applications (ASIO2, WDM, MME, Apple Core Audio and Core MIDI supported)
I/O Configuration:
Two XTC™ Class-A, ultra-low noise, Mic/Line/Hi-Z preamps. Balanced XLR, 1/4" TRS and 1/8" Inputs (-127dB EIN) with 60dB of gain
1/8" Stereo Condenser Microphone Input with 5V Power
Two 1/4" Balanced/Unbalanced Outputs (112dB SNR)
Two 1/4" Unbalanced Send/Return Inserts prior to A/D converters
Stereo headphone output (112dB SNR)
ztv
