FOCAL SUB6
vlasis
Φωτογράφος!
το εχει ακουσει καποιο παιδακι απο εσας?
The main features of the Focal SUB 6 BE include:
  • 350W Active subwoofer for professional monitoring sytems
  • Perfect for use in music production, post-production or broadcast applications
  • Frequency response: 30Hz-250Hz
  • Maximum SPL: 116 dB SPL (peak@1m)
  • Input - Type/impedance: Left, Right, LFE Electronically balanced / 10 kOhms. Connector: Female 3 pins XLR. Sensitivity: Variable
  • Output (to satellites) - Type/impedance: Left, Right Electronically balanced/50 Ohms. Connector: Male 3 pins XLR
  • Amplifier: 300 W rms, BASH technology
  • Internal processing and functions: Left + Right mono summation, LFE+lo-passed mono sum, 24dB/octave variable lo-pass filter, Phase adjustment, Polarity, 24dB/octave, defeatable hi-pass filters with selectable frequency
  • User controls: Sub level (sensitivity) adjustment, Lo-pass frequency adjustment, Phase adjustment, Polarity switch, Mute, 2.1 bypass (controlled by external footswitch), Hi-pass frequency selection, Hi-pass defeat
  • Indicator (LED's): Power on, Mute, Hi-pass defeat
  • Power supply - Mains voltage, Connection 230V (T1.6AL fuse rating) or 115V (T3.15AL fuse rating), IEC inlet and detachable power cord
  • Transducer: Subwoofer "W" composite sandwich cone, high excursion Focal 11W7670 270mm (10.6 inch) drive unit
  • Cabinet Construction: 19mm MDF panels internally braced
  • Finish: Real red veneer sides - Black on body
  • Dimensions (HxWxD): 380 x 344 x 440mm (15 x 13.5 x 17.3)
  • Weight: 23kg (50.7lb)
vlasis
Φωτογράφος!
Απάντηση: FOCAL SUB6
ευχαριστω σας κυριοι......απλα ειχα μια κουβεντα με 2 τυπακια και μου ειπαν γιαυτο το sub οτι παιζει πολυ καλα......ετσι μπηκε και η αρωτηξις........
πολυ καλα ? ποσο πολυ ?
υπηρξε καποιο μετρο συγκρισης online ή απλα παιζει πολυ καλα ?
manos.papadopoulos
