Focusrite Liquid Mix εξωτερικό DSP ήχου
xfader
Ένα ενδιαφέρον εξωτερικό DSP με αποκλειστικά tasks: vintage EQ και compressor.
Σύνδεση: Firewire 400
"Each of Liquid Mix’s 32 channels provides EQ and Compressor emulations selected from a huge pool of high-quality vintage and modern day classics. 20 EQs and 40 Compressors are available straight out of the box, with an expanding library online. Furthermore, a totally unique hybrid 7-band ‘super EQ’ can be built out of separate classic EQ sections in every one of the 32 channels. Each channel appears as a separate VST/AU/RTAS effect within the sequencer and will work within all major applications, including Pro Tools.
Liquid Mix uses the same patented Dynamic Convolution process as Focusrite’s Liquid Channel. Unlike standard convolution techniques, Dynamic Convolution utilizes vast processing power to sample the effect of a classic processor on a series of audio pulses, at many different gain settings and all frequencies. In Liquid Mix, all this processing is done using onboard DSP, so the processing has almost no effect on your computer’s own CPU."
http://www.focusrite.com/product/liquid_mix/
bmavroeidis
