vlasis
Φωτογράφος!
http://samplerateconverter.com/mscn/hd-audio-converter.php
Για Windows και Mac.....
Integrated tool = AUDIO FILE CONVERTER + CD AUDIO to FILE CONVERTER
A lot audio formats convert ability: mp3, wav, flac, dsf, aiff, aiff/sowt (Mac OS X CD format), alac, ogg, aac (m4a), wma, dts, ac3, ape
Simple communication software with user (OPEN file - SELECT format - CONVERT)
Suppression "hiss" (during playback) capability for some high resolution (192/96 kHz) audio files
Add custom formats of converted files ability
Competent technical support. Technical support for non-free versions only. But even if you use FREE version or think about it, you can anyway ask question here...
