Fujitsu Launches Full HD Multi-Decoder LSI Supporting Both MPEG-2 and H.264.
HV
Fujitsu Limited today announced the launch of a new full high-definition (HD) multi-standard video decoder LSI for Digital Video Broadcasting (DVB(1)) HD broadcasts, that decodes both MPEG-2(2) and H.264(3) compression formats in full HD resolution (1920 dots x 1080 lines). Sample shipment of the new LSI, the MB86H60, will start from the end of May 2008.
This LSI is a highly integrated System-on-Chip (SoC) for televisions, set-top-boxes (STBs), and portable receivers and complies with the DVB standard currently used in various regions, mainly Europe. The LSI decodes full HD video compressed in either MPEG-2 or H.264 and integrates on a single chip the necessary processing functions for a HD broadcast receiver, including processing of digital video, audio, and graphics. This makes the multi-decoder suitable for TVs, STBs, and portable TV receivers. Also, as the LSI's functions can be employed with the addition of only two 16-bit wide external memory chips, it allows set vendors to reduce their overall costs when designing their TVs and STBs.
Figure 1: Fujitsu's full HD multi-decoder LSI, MB86H60
Larger View
The DVB digital broadcasting standard is used in Europe, Russia, the Middle East, and by some broadcast systems in China, which are currently broadcasting in standard definition(SD) using the MPEG-2 video compression format. Next-generation broadcasts will be in HD, and in Europe it has been decided that H.264 will be the main format to be used. Since the shift to next-generation HD broadcasts in Europe and elsewhere will occur gradually over time, decoder LSIs used in TVs and set-top boxes for these regions need to be able to handle decoding of both MPEG-2 and H.264 formats.
Following HD broadcasting in Japan and the US, for the ramp up of HD broadcasting in Europe, Fujitsu built on its expertise and experience of the previously released SmartMPEG series along with H.264 decoder technology co-developed with Fujitsu Laboratories Limited, to offer this multi-decoder, MB86H60, capable of supporting both MPEG-2 and H.264 video compression formats on a single chip.
Sample Pricing and Shipment
ProductSample PriceShipment StartMB86H605,000 JPYFrom end of May 2008
Product Features
  1. Decodes both full HD MPEG-2 and H.264, supporting current and next-generation European broadcasting standards.
    This multi-decoder LSI can be used for current standard-definition MPEG-2 broadcasts used widely in Europe and other regions, and for next-generation HD broadcasts using H.264.
  2. Integrates on a single chip functions necessary for HD TV processing
    The CPU core in the LSI is the high-performance ARM1176JZF-S™, which supports a wide range of functions including system control for TVs and STBs, teletext(4), subtitles, and JPEG decoding(5). In addition, by integrating audio, graphic video processing, and functions required for processing HD broadcasts on one chip, Fujitsu's full HD multi-decoder LSI enables set vendors to more easily construct their systems.
  3. Complete Functionality by Adding Two 16-bit wide DDR2-SDRAMs
    By simply connecting two 16-bit wide DDR2 SDRAM667 external memory chips as working memory to the multi-decoder chip, the chip becomes fully functional, including CPU-based system control and digital-video decoding. This allows set vendors to reduce the overall cost of their systems.
  4. Four video-transfer ports for connectivity to various devices
    With four video-transfer ports, this multi-decoder LSI can be connected to a wide variety of external devices. For example, the LSI makes it possible to connect to digital video recorders (DVRs) which record TV broadcasts to a hard disk drive, or to connect to a conditional access card to view restricted digital broadcasts.
PDF Key Specifications [20KB]
lakiss51
Απάντηση: Fujitsu Launches Full HD Multi-Decoder LSI Supporting Both MPEG-2 and H.264
Αν καταλαβα καλα, απο στανταρ σημα μη υψηλης ευκρινειας θα παιρνουμε HD;
Atoll
