Ultra Audio
Διατίθεται μεταχειρισμένο πολύπριζο 6 θέσεων, Furutech e-TP60E, Ιαπωνίας με τεχνολογία GC-303.
Τελική τιμή προσφοράς, 190 ευρώ. (τιμή Λιανικής 360 ευρώ).
Αντικαταβολή και αποστολή σε όλη την Ελλάδα.
Και έως 6 άτοκες δόσεις με πιστωτική.
Πληροφορίες 2103839399
South Sounds
Λήμνου 8, Δάφνη (πλησίον μετρό Αγ. Ιωάννης).
Furutech e-TP60E, πολύπριζο 6 θέσεων, αλουμινίου 10Α 250V 50/60Hz, 2500 W, με επιχρύσα 24Κ βύσματα Inlet και Schuko. Χωρίς φίλτρο ρεύματος, με υλικό GC-303 για την απόσβεση των EMI, μεταλλικά αντιμαγνητικά μέρη, διαστάσεις 200 X 130 X 60mm και βάρος 0.95Kg,
The e-TP60 is a sophisticated, luxuriously made power distributor that eliminates many common problems found with audio and video components caused by massively contaminated electrical power.
The AC waveform becomes severely distorted by ground noise, voltage spikes and sags,high frequency power supply noise from other components in your own system, plus radiated high frequency digital noise from processors and digital interconnects.
There are also distortion products at the top and bottom of the AC waveform created by switch-mode power supplies in electronic devices on the same circuit. Additionally, you’re never alone; your residential AC mains supply is shared with other apartments, homes, and businesses on the same utility transformer. That’s why many audio and video enthusiasts notice their systems are more enjoyable late at night or on weekends!
The beautifully crafted special grade aluminum chassis effectively shields against another common problem,
RFI (Radio Frequency Interference), and a layer of Formula GC-303 blocks EMI (Electro Magnetic Interference).
Internal wiring is FURUTECH μ-14 wire(14 AWG) that guarantees low resistance.
Furutech Hyper Quality High Performance Receptacles are wired to the IEC AC input of the e-TP60.
Receptacles feature 24k gold-plated phosphor bronze, non-magnetic conductors for stable, long lasting, optimized power transfer.
Furutech’s Two-Stage Cryogenic and Demagnetization Alpha Process
The Final Result
The 2-Step Cryogenic and Demagnetizing Alpha Process works in tandem with other design-in features to create the most optimized AC power transfer possible.
Furutech’s total awareness and devotion to detail results in a greater sense of power, dynamics, and resolution, with cleaner, blacker backgrounds and a larger, more stable soundstage, vivid tonal colors and deeper extension at both ends of the frequency range.
The e-TP60 will allow the delicacy, refinement and nuance of a performance through, along with micro- and macro-dynamics that will leave you breathlessly engaged. Displays of all types will exhibit greater, sharper resolution with less ghosting, color shift, “snow”, or vertical and horizontal lines.
Τεχνικά Χαρακτηριστικά:
VOLTAGE AC 125V 50/60Hz
CURRENT 15A
Outlets 6 Outlets
Dimensions 200X130X60 mm
WEIGHT 0.94Kgs
Formula GC-303: GC-303 is a special material that Furutech layers and bonds to the interior bottom-plate of the chassis. It actually absorbs EMI (Electromagnetic Interference) generated by the internal fittings of the unit. The e-TP80E uses no other filtering besides GC-303 so AC resistance is kept to a minimum, allowing a more resolving, powerful, dynamic, and colorful performance from your components
South Sounds
The Final Result
CURRENT 15A
Outlets 6 Outlets
WEIGHT 0.94Kgs
209,5 KB Προβολές: 0
164,7 KB Προβολές: 0
