GamuT Audio DI 150
Σπύρος Μπλάτσιος
Διακεκριμένο μέλος
Ολοκληρωμένος ενισχυτής από την GamuT.
Shipping weight 30 kg
Dimensions 155 x 431 x 410 mm + terminals
Idle power consumption 100 W
Continuous output power at 230V mains voltage 2 x 180 W / 8 Ohms
2 x 360 W / 4 Ohms
Accepted voltage range 190 - 250V AC
Noise level > 100dBA below 100W / 8Ohms
THD < 0.05%
Distortion mainly 2nd harmonic, decreases with higher output level.
Speaker loads > 1.5 ohms
Active balanced input impedance 40 kOhm (pin 2 +, pin 3 -, pin 1 GND)
RCA input 20 kOhm
Speaker connections WBT sockets can accommodate 4 mm banana plugs, lugs or stripped wire.
Power supply 2 x 450VA toroidial transformer and 64.000uF RIFA capacitance
  • rose.athens
bmavroeidis
