Gearbest - Universal Snap N Grip Wrench
xfader
Gearbest - 2PCS Universal Snap N Grip Wrench Set Adjustable Spanner Kit
$14.88
Σετ διπλού αυτορυθμιζόμενου πολυεργαλείου για βίδες και παξιμάδια από 9mm μέχρι 22mm.
Main Features:
● Two universal wrenches for all nuts and bolts. The small wrench has a different-sized head on each end, while the large wrench has a single large head for bigger nuts and bolts.
● Lightweight and self-adjusting set fits 9mm to 32mm.
● Automatically fits to the size and shape of nuts and bolts.
● Efficient, practical and easy to use.
● Ideal solution to all your problems with taps, valves, pipes, boilers, wheels, etc.
mpalo
