Gradient Evidence
m1ts0s
News poster
Gradient Evidence is our most versatile loudspeaker model. It is based on the same unique design concept as Gradient’s flagship model Gradient Revolution. This Revolution’s little brother is at home in room environments where other speaker models are producing rather colored sound.
Music reproduced by Gradient Evidence is directed straight towards listener and thus disturbing room reflections are not affecting the sound quality.
This model proves that a HiFi loudspeaker can be used in all kinds of rooms and even against the wall and in very small rooms, without sacrificing the quality of reproduced music.
Gradient Evidence can also be used as main loudspeaker for high quality home theater systems.
Radiation Patterns Bass: sphere
Midrange & treble: cardioid
Frequency Response 45-20000Hz +/-2dB, 29Hz -6dB
High frequency limit above 50kHz
Impedance 4 Ohms
Sensitivity 86dB/2.83V/1m
Rec. amplifier power 50-250W
Drivers 1x200mm long throw woofer,
176mm fibreglass midrange,
coaxial aluminum dome 25mm
Crossover frequencies 200Hz and 2800Hz
Bass level adjustment, 3dB
περίπου στα 2500 ευρώ το ζεύγος
http://www.gradient.fi/Gradient/Evidence.html
papaevagelouv
