Αγορασμενη 900 ευρω την πηρα σα δωρο γαμου αλλα λογω οτι εχω την τηλεοραση σε επιπλο δεν τη χρησιμοποιησα ποτε. Ειναι στο κουτι της ολοκαινουργια!!!
Τιμη 500ευρω.
Eπισης με αλλα 50 ευρω δινεται και το εξαρτημα CM7AC2 για ακομα περισσοτερες απο 60 ιντσες τηλεοραση.
Features of Chief CM7W12U Automated Swing Arm Mount:
1. Ultimate Flexibility: Extends up to 12” (305 mm), tilts +7˚/-20˚ and swivels up to 28˚ for
maximum range of motion.
2. Preset positions: Two preset buttons on remote to program favorite viewing positions.
3. Multiple Control options: Control options include: RS232 interface, two programmable
viewing options, and IR remote (included).
4. Cable management: Hidden cable management and mechanism protected by decorative
cover for finished look.
5. Low Profile: Collapses to 4.6” (305 mm), concealing mount behind the screen.
6. Mounts directly to studs for easy on-wall installation.
7. Decorative cover provides a finished look.
8. NOTE: CM7AC2 accessory required to fit larger screens up to 63"
Specifications:
Extension:
4.6-12" (117-305 mm)
Tilt:
+7°/-20°
Swivel:
Up to 28° left/right
Dimensions (H x W x D):
22.64" x 26.57" x 4.6" (575 x 675 x 305 mm)
Mounting Pattern Range:
546 x 100 mm up to 660 x 470 mm
Mounting Bracket Accessories:
CM7AC1: 100 x 100 mm up to 546 x 470 mm
CM7AC2: 660 x 470 mm up to 876 x 700 mm
Color:
Black
Weight Capacity:
180 lbs (81.6 kg)
Τιμη 500ευρω.
Specifications:
Extension:
Tilt:
+7°/-20°
Swivel:
Color:
Black
Weight Capacity:
180 lbs (81.6 kg)
